Old 01-07-2003, 06:37 PM
batesjm's Avatar
batesjm batesjm is offline
My Alter Ego Is Retarded
Bit Plane
I just bought a Fit Racer at a gas station today to begin my latest project. I did a forum search to see what all of you have tried. Looks to me that they were all balsa planes or moded rubber band planes. I plan to use a peice of thermoformed Lexan for a fuselage and hopefully two 2.2 motors (one on each wing).
I will probably use a peice of foam for the wings. I have already got the wing mocked up and a foam template for the fuselage. The only concern I have is the radio only having two channels. This leaves me with two choices: wire the motor(s) constantly on, or fix the elevator. It may take me some time to get the correct setting, but i think it will be worth it. I will post pics as i progress through the project. I am really looking forward to getting some input on this.
Thanks,
Josh
Old 01-07-2003, 07:26 PM
sessiz10's Avatar
sessiz10 sessiz10 is offline
Told ya.
I was interested in making a bit plane , but the only instructions I could find were in asian and they wouldn't transalate at all. Do you have a link or links to some more info on making a bit plane?
____________________
Meh.
Old 01-07-2003, 09:07 PM
batesjm's Avatar
no, i plan on doing this from scratch. there are some other mentions of this in the forums, just do a search.
I like Pie
Old 01-07-2003, 09:12 PM
blacksabbath070's Avatar
blacksabbath070 blacksabbath070 is offline
IRON MAN OF BIT RACING
hey
here you go on pics i grabbed these pics from this link: http://www.palmislife.com/cgi-bin/ut...1&bpg=5&age=30 here are the pics
MY NEW CUSTOMIZED BIT:
red ae86 with zipzap spoiler
carbon fiber hood
3.8 motor (well, it doesnt want to run now)
qfm springs
back wheels on front and back
8.25:1 gearing
rare earth magnet steering
and
there are also links to a movie on it flying there
carbon fiber hood
qfm springs
8.25:1 gearing
Old 01-07-2003, 09:16 PM
JTM's Avatar
JTM JTM is offline
1 4M 70 1337 4U
Send a message via AIM to JTM
WELL you could use two pcb, or split the chans and make it kinda like a 4 chan up down left right with fixed motors (on) if u used two pcbs (diff freq) u could really do some crazy shiznit. do a dual cell onit for each motor.. and those lil bastards would fly...
batesjm's Avatar
ive seen those before
I like Pie
Old 01-07-2003, 09:21 PM
batesjm's Avatar
i want to make sure i can get it to fly before i get to crazy. 1 pcb, 1 battery and mabye two motors.
I like Pie
Old 01-07-2003, 11:35 PM
rpm3j rpm3j is offline
Bit plane links.
Gentlemen,
There is already a large body of knowledge out there on Bit planes, it's just not in these forums. Check out some of the posts in the indoor and micro flight forum over at RC Groups:
http://www.rcgroups.com/forums/forum...php?forumid=85
From what I've read, it's kind of tricky. You have to build a gearbox, and use a li-poly battery to save weight and pump up the voltage. You should shoot for an AUW under 20g. You will also need to boost the range of your controller, and might want to add a MOSFET to the RX to boost motor output and add 2 or 3 step proportional throttle. Check out the mods on:
www.rc-cam.com
The range mod on a decrippled Tx will give you about 200'! Working with a free flight model and ditching the bit motor can really help! Good luck!
-rpm
Old 01-08-2003, 10:53 PM
batesjm's Avatar
Well, I'm back to the drawing boaur on a design for the fuselage, I decided that my precious design was not exactly what I wanted, it just didnt look right.I have come up with a design i like and will start on the buck tomorrow or friday. This may take a while. I suppose i could just mod a rubberband plane or a glider, but i want it to look somewhat like a real plane. Thanks for the links above they were a real kick in the ass to get me going on this. If I can get this figured out i may sell a wing and fusealage kit akong with instructions on how to put the bit electronics in. If anyone sees any other links that may be helpful post them or e-mail me.
Thanks
Josh
Old 01-11-2003, 01:16 PM
tinyrc's Avatar
tinyrc tinyrc is offline
batesjm, keep us posted on your progress!
Old 01-13-2003, 11:26 AM
batesjm's Avatar
Well, after a hectic weekend I am still not started on the buck, but i am coming along with the internal mechanics of the plane. I plan on mounting a small diameter rod to the steering mechanisim and running it directly to the rudder. I also decided to go with one motor for now, I figure that will move enough ari to get the plane off the ground. I would also like to try a 3.8 spinner for more rpm on the prop. The problem is I dont know if the little motor has enough torque to maintain a constant speed that is close to 38000 rpm. For now I may just try a 3.0, any thoughts?
Till next time,
Josh
I like Pie
Paper Bird 1 (home made bit plane) Comrade_Boris Micro Flight 10 10-27-2003 08:20 PM
bit plane nomad Bit Char-G / MicroSizers 26 08-14-2003 07:54 AM
