Old 01-07-2003, 04:53 PM
VuN86
zz motor to micro motors
hey all i was wondering what each zz motor is equal to when compared to micro motors and which is faster the zz turbo or the zz nos? cause isn't turbo better the nos in reality?? i don't know that's what i heard somewhere
Old 01-07-2003, 05:00 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
ya just like i heard that putting a really huge wing on the back of your car makes it really fast. almost as fast as putting stickers on sides of your car.
Old 01-07-2003, 05:35 PM
isk8blind's Avatar
isk8element too.
the nos
the nos is faster in the zz its 23,500 and the turbo is 21,600 but in real life nos makes your car hit top speed and maybe go faster now i said maybe a bit faster
Old 01-07-2003, 06:00 PM
cisco cisco is offline
Yeah the nos is faster than the turbo.
Old 01-07-2003, 07:50 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
For loads of fun, try a zz turbo, NOS or DKS 2.8 in your bit. You have to cram it in though.
Old 01-07-2003, 08:01 PM
ShadowMage's Avatar
ShadowMage ShadowMage is offline
Box Racer
Send a message via ICQ to ShadowMage Send a message via AIM to ShadowMage
go w/ turbo! not as fast as the NOS engine but it blows away a 2.2 in torque. It's my personal fave anyway.
Underground Dweller: If I were you, I'd start running!
Buddy: If you were me, you'd be good lookin'.
--Quote from Six String Samurai
Old 01-07-2003, 10:38 PM
shocon2k
In real life turbo will beat the hell out of nitrous. If you spray your engine then you'll most likely just roast your tires off the line and melt your piston heads after a few months. With turbo, you get constant power more evenly distributed and you can drive around and learn how to use it. Completely unrelated to the topic of this post but hey, turbo all the way!
Old 01-07-2003, 10:43 PM
ShadowMage's Avatar
Box Racer
Amen, shocon!
Old 01-07-2003, 10:55 PM
Pharmaceutical
Well technically if you roast your pistons you must have a Civic, thats really the only car I know that can't hold much of anything (turbo, or nitrous). But anything should be fine with a 50 shot of NAWWWZZZ! A turbo is also four times the price of any nitrous kit. But anyway, I really like the turbo motor for the ZZ better because it has way more torque than the NOS motor. I use my NOS motor in my Wild Char-g and it works fine because the gearing in those is specifically for torque.
Old 01-07-2003, 11:09 PM
zipsnbits zipsnbits is offline
mmmmmmmm bittssss
Send a message via AIM to zipsnbits
first of all you cant use nitrous until you hit 5000rpms in real life and if your lucky that is in 4th or 5th gear, and the same goes with a turbo, it doesnt spool up until it hits a certain rpm factor, you just dont hit the gas and oh hey your turbo is on lol. but i think with the best motor go with the nitrous, and the green gears your bit will be smokin by the time you hit the foward button.
you call that a 10 second car? more like a 10 minute car, you cant even push that across the finish line!!
Old 01-08-2003, 12:10 AM
shocon2k
Nitrous engages when your gas pedal goes to the floor. It turns on the nozzles when the throttle body position sensor detects WOT. So if you punch it off the line (which is stupid if you have any power, cuz you'll just smoke your tires) you could spray from low RPMs. Again, it would be stupid, because a 50 shot at 1000 rpm would be like doing a 300 shot at 6000 rpm.
Turbo does not engage off the line, however it gives a lot more power in the straightaways and once you're moving.
Nitrous costs less because its a temporary system, and constantly needs refills if you use it. Turbo sits on your engine pretty much as long as you have the car and requires very little maintenance.
Civics can handle turbo and nitrous, Honda blocks are built very sturdy, and they put out a lot of hp per liter. They have the capability to do a lot more. Look at the S2000 for instance. NA its 225 hp in a 4 cylinder.
I think I've addressed every issue so far.
Oh yeah, if you are serious about turbo, any smart car guy will tell you to build your internals to handle extra psi.
Boosting 15 psi on a stock block is like spraying off the line, it'll end your run real fast.
Old 01-08-2003, 05:04 PM
VuN86
real life not bit
does anyone know which would be better to do? i want to get a 86-90 i guess i wanna get the 2+2 so 4 people can be in my car but which would be a better way of going just going with the rx-7 turbo tpye or to upgrade to a turbo?
ever since watching initial d i just love the ae86 and well the rx-7 i always liked well thanks for the info about the zz motors too
o in addition which is better a microsizer or a zip zap and why? i'm not sure what to but yet
Thanks
motors and pinions? sawhit4 Bit Char-G / MicroSizers 0 06-04-2005 05:43 PM
Making motors faster. moebrown20 XMODS Mods and Projects 0 10-15-2004 03:01 PM
Xmods Video MicroRCEngineering XMODS 10 01-24-2004 11:39 AM
bit motors...ZZ motors....DKS motors tarnjit ZipZaps 1 12-06-2002 05:06 PM
