01-07-2003, 07:03 AM
Break it in????
How do you do this with a char-g. I know with the big gas cars you have to put about for a couple of tanks.
Do you just drive it as normal or do you have to prop up the back wheels and let them spin for a while.
You know why?.... Because he can!
01-07-2003, 07:24 AM
Regulator
just drive it normally and after about 4-5 charges and runs it should be broken in
01-07-2003, 08:01 AM
ok thanx
01-07-2003, 08:50 AM
A must-do!!!!
I have found that my cars run much better if I break in a new motor. I do this by putting the motor in the car, charging the battery, putting the car upside down on its roof, and running the motor with no load - for (2) battery charges.
On the first charge, I will alternate going backwards and forwards, for about 45-60 seconds in each direction. On the second charge I only go in forward, until the battery is drained.
This breaks in the motor commutator brushes and makes for a better performing car!
John
"It takes a Mopar to catch a Mopar!" - Vanishing Point
01-07-2003, 10:09 AM
cool thanx.
ill do that with the new engines
01-07-2003, 02:36 PM
MSN:eric_exec@hotmail.com
Thanks for the tip
