Go Back   TinyRC.com > 1/64 and Smaller > Bit Char-G, MicroSizers, Z-Cars, Clones > Wild Char-G
Old 01-05-2003, 04:58 PM
DisfourDan DisfourDan is offline
Antenna Weight mod
Since the Wild Char-g is so unbalanced, which means it cant climb steep hills, i decided to add weight. I wanted to make it more balanced but at the same time not put too much weight on it. So what i did was, remove the stock car antenna and replace it with a larger gauge wire, i think 22. Then at the tip of that wire, i glued (epoxy putty) a lead fishing weight. Then i bent the wire forward (in front of the car), to give a lever effect on the car.
Thus now, the car is more balanced and climbs hills with ease.
Nothing good can come from good.
Old 01-07-2003, 09:20 AM
T_T_52
Ya but does it effect the steering?
Old 01-07-2003, 01:05 PM
no it does not effect the steering. why would you think that it would?
Old 01-07-2003, 02:03 PM
T_T_52
Because when with my truck there is a little weight in the front the truck can't steer without a rear counter weight
Old 01-07-2003, 05:21 PM
it is probably because there is too much weight, but i know for a fact that my antenna weight mod does not affect my steering.
Old 01-08-2003, 03:35 AM
Ganpachi Ganpachi is offline
I was thinking of putting a battery on top of where the claw motor is for my wildchar. figure if i go 2.4V the extra weight of the battery shouldn't make a big dif. Since my cuz lost my claw I'm thinking of taking out that 2nd motor and putting the 2nd battery somewhere down there. 2.4V to my 3.0 motor...should give the wild char respectable speed...
Old 01-14-2003, 09:02 AM
T_T_52
gepachi just put your second cell in the chassi in front of the first. It will be tight if you sand the area down.
still another antenna mod chilli_mp138 ZipZaps Mods and Projects 2 02-04-2005 11:39 PM
help :( antenna mod :( crip. cap. soggyrice.mMmMm Bit Char-G / MicroSizers 3 03-17-2003 07:04 PM
The perfect antenna Mod...for anyone Johnaten ZipZaps 3 11-10-2002 09:32 PM
Question about telescoping antenna mod...? SPEED QFM Racing Customer Support 2 10-15-2002 07:07 PM
ZipZaps: Antenna Mod pics available in Gallery Namuna Bit Char-G Mods and Projects 2 09-25-2002 11:13 AM
