Old 01-05-2003, 04:10 AM
Leoslan
My light mod (pics)
Here are a few pics of the light mod that I did. I tried it on a Bit clone first to see if it would work. I am going to replace the headlights with lights from a mini maglight flashlight. They are like 1000 times brighter and you can run 2 of them off a 3 volt battery. The only problem that I have is that I hooked 4 LED's to one 3 volt battery and they seem kinda dim even with the resistors. I could add a second 3 volt battery, but space in my car is at a premium. Do they make a 6 volt lithium battery?
Old 01-05-2003, 01:08 PM
BCGMan BCGMan is offline
What kind of resistor are you using (what color on them)? Can you tell me what's the advantage of using it? Thanks
BCGMan
Old 01-05-2003, 01:48 PM
Leoslan
I used 100 ohm resistors (gold/red/black/red). You can get them at RS. I couldn't get all the lights to work at the same time without them. I used 2 resistors, 1 for the tail lights and 1 for the headlights.
Old 01-05-2003, 02:06 PM
Thanks, do you know how to make the light active only when you press forward or backward w/out using a switch. Lmk, thanks
BCGMan
Old 01-05-2003, 02:12 PM
Leoslan
No, this was only the second mod that I've attempted. Sorry.
Old 01-05-2003, 02:57 PM
xatu's Avatar
xatu xatu is offline
they say im slooooow eh?
Do the lights come out of the body? Because the last time I saw LED's at RS, they were big, and wouldn't fit inside the body without rubbing against tires...
BTW, it looks awesome!
Old 01-05-2003, 05:01 PM
krackle krackle is offline
but how do you turn the lights on and off ?
Old 01-05-2003, 06:39 PM
t-squared's Avatar
t-squared t-squared is offline
Bit Obessed...
...but space in my car is at a premium
Looking at your pic, it seems like the wiring takes up the most space, why don't you switch to enamel wire then?
and that's a HUGE switch on the roof of your car!!!
Old 01-05-2003, 07:06 PM
By the way, does it matter which side of the resistor being hook to? Is there a + or - like capacitor? Lmk, thanks
BCGMan
Old 01-05-2003, 11:23 PM
Leoslan
Yes, the lights can be taken in and out. You can get a 20 pack of assorted LEDs at RS for a couple bucks. I used the 3 mm ones.
Old 01-05-2003, 11:33 PM
Leoslan
I used 28 AMG wire, which was too big. I redid the wiring with CAT5 wire and it worked better. I also switched to smaller size batteries, but the same voltage and put 3 together, which gave me 9 volts so I could eliminate the resistors.
Lol! I know...it was the smallest micro switch I could find at RS.
No, I don't think so.
Old 01-06-2003, 06:04 AM
Spanky's Avatar
Spanky Spanky is offline
Mr. Goop
you should place the switch out the back of your car and use it as a wheelie bar!! i like it.
Old 01-06-2003, 07:11 PM
InGaN's Avatar
InGaN InGaN is offline
GaN: Blue
Re: My light mod (pics)
I don't think so. If you have enough room, try stacking two CR2016 batteries under the roof. They add up to 6 volts and might fit, but that depends on the shape of the car. I have a Mitsubishi Lancer MS, and that is what I'll use for my light mod.
< Plane construction paused>
Current Progress: 0%
Old 01-06-2003, 07:25 PM
scottyboyfun's Avatar
scottyboyfun scottyboyfun is offline
Im a cat, miow.
Send a message via Yahoo to scottyboyfun
Heres my SMD LED setup.
So what do u lot think?
Post it!
Im a cat, miow.
front view
Post it!
Track and Antenna Mod pics Robotguy ZipZaps SE 2 04-12-2005 02:01 PM
Super light mod gek Bit Char-G Mods and Projects 17 11-17-2002 09:03 AM
Beginner and Ultimate Light Mod DigitalAce7 Bit Char-G Mods and Projects 4 11-12-2002 12:45 PM
fIbEr OpTiC lIgHt mOd...?? JojoPB Bit Char-G Mods and Projects 2 10-18-2002 07:54 AM
QFM Monster Truck Mod Pics QFM Racing Bit Char-G / MicroSizers 2 08-22-2002 01:56 AM
