01-04-2003, 11:45 PM
isk8element too.
how to make my micro pull wheelies?
01-04-2003, 11:47 PM
<(- -)> <- Yoda
either add some wight to the back or do a dual cell mod
wooo hooo!
01-04-2003, 11:53 PM
Box Racer
or get a the Panda NSX-R BCG set.  With that zz turbo motor I was able to pop wheelies with no extra weight in the back and (other than the engine) totally stock.
Underground Dweller: If I were you, I'd start running!
Buddy: If you were me, you'd be good lookin'.
--Quote from Six String Samurai
01-04-2003, 11:55 PM
isk8element too.
i do
i do have a zz turbo it makes it pop a liitle but for like half a sec.
01-04-2003, 11:58 PM
Box Racer
Yeah I kinda guessed that you had that since you posted your setup in your first message.
Ah so you're wanting to pop wheelies for extended periods then...weeeeeell...then listen to Impreza WR reX
01-05-2003, 12:37 AM
wrx is right. dual cell mod would be a good way to go... plus u get more runtime
01-05-2003, 08:42 AM
Got Avatar?
a controller weelie would look sooo cool!
at the moment with my bit, i cant only get about .0001 second welie action unmoded.............workin on it
01-05-2003, 09:07 AM
1 4M 70 1337 4U
pics of my dual cell mod
01-05-2003, 09:08 AM
1 4M 70 1337 4U
after smoothing all the stuff out of it and removing the metal charging bits.. do this..
01-05-2003, 09:09 AM
1 4M 70 1337 4U
as u can see they extend the full length of the chassis now.. next stpe make the batt pack
01-05-2003, 09:10 AM
1 4M 70 1337 4U
i soldered a thin piece of metal to the other end and insulated it with electric tape. now put it into your chassis with the pos side to the passenger
01-05-2003, 09:12 AM
1 4M 70 1337 4U
of course that pic dotn show it too well but thats b/c i had them in upside down  tape goes up now you have yer batts in.. now tape everythign together as now your pcb cover wont fit.. make sur eno metal is touching metal.. u may wanna cover your heat sink with some tape  and tape down yer batt pack so it wotn move around..
01-05-2003, 09:14 AM
what tires are u using to make it pop?
hard dont work
A man who desired nothing is invincible.
01-05-2003, 09:17 AM
1 4M 70 1337 4U
after tape
01-05-2003, 09:19 AM
1 4M 70 1337 4U
with body  damn sweet handling too b/c the center of gravity is moved down (compared to some other dual cell mods) also its centered so no wheelies it just hauls ass and hardly flips.. itll do tight lil circles faster than anything..
