Old 01-04-2003, 07:21 PM
Mike the Great Mike the Great is offline
Send a message via ICQ to Mike the Great
clone gears vs bit gears ?
what is the differecne between clone gears and bit gears ??
if they are the same what ratio are they ?
Old 01-04-2003, 11:52 PM
isk8blind's Avatar
isk8element too.
it depends
it depends what clone and what real car
Old 01-05-2003, 12:02 PM
strider_mt2k
I have the same question.
Is the color coding universal on gear/rear sets?
Old 01-11-2003, 03:12 PM
arceeguy
I have found that color coding is inconsistent with the clone manufacturers. This goes for gears AND motors. The only time colors mean anything is with genuine Tomy or MicroSizers parts and accessories.
Old 01-11-2003, 09:43 PM
AzNRocket's Avatar
AzNRocket AzNRocket is offline
AzN InvAzN
yes
Old 01-11-2003, 11:17 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
No. ZipZaps are slightly larger.
Old 01-13-2003, 04:24 PM
strider_mt2k
I originally transplanted my red "turbo" gear onto my shen's axle for looks, as it meant keeping my stock chromes, and the speed of the ZZ red "turbo" gear.
Well I went to a hobby shop today and plunked down 6 bux for the "Wheel and Gear Tuning Set" (HCAC1303) and I am VERY impressed!
There is a difference between the Zip Zaps gears and the Bit gears!
My fast car is slightly faster now since I put in the 8.25:1 set (light green), and slightly quieter when running.
I also noticed that the overall quality of the wheels is nicer than my clone too, so I think I will be using Bit parts on my shen from now on.
added note:
QFM's articles say this, I just learned for myself!
Old 01-13-2003, 04:30 PM
arceeguy
I have noticed that the Tomy/MicroSizers gears are of higher quality too! (especially the pinion gear)
Old 01-14-2003, 06:57 AM
strider_mt2k
Question
I guess my big question is if the rears/gears go higher than 8.25:1 or is that the tops for speed gearing?
Old 01-14-2003, 04:50 PM
arceeguy
8.25:1 is the lowest "official" ratio for the BCG.
Hot Wheels KIT racer axles and gears can be used with minor mods to the axle, but IMO, the ratios are too "tall" to be practical with a BCG.
Old 01-19-2003, 01:05 AM
BenCloned's Avatar
BenCloned BenCloned is offline
Clones Are Good
My Bensu Clone came with 12:1 gears, but with an 8 tooth pinion gear, which results in 7.25:1 (approximately). I bought the Microsizer axle/gear set, and got the following:
1. Tomy axles are .0035" larger, so I had to bore out mt chassis
2. With the 8 tooth pinion, most of the standard color combo gears didn't work well, but I did get a few good combos to run.
Blue spur / orange axle (best running)- 7:1
orange / aqua- 5.65:1
orange / orange- 6.25:1
I couldn't use the aqua spur at all, because the mesh was too tight, and would bind, and I couldn't use the 6 tooth pinion, as it wouldn't contact the spur at all.
I don't know if this helps anyone, but it'll work for the gee-whiz file.
Shen Qi Wei:
Begun this clone war has.
- Yoda
Monster Tri-Cell Bit Clone Tech_Lord Bit Char-G Mods and Projects 1 11-24-2005 02:11 AM
Albersons $9.99 Bit Clone Review robz28 Bit Char-G / MicroSizers 2 01-16-2003 07:51 PM
Bit Charg-G Clone FAQ soulstice Bit Char-G / MicroSizers 2 09-10-2002 06:28 PM
