01-03-2003, 10:51 AM
Xmodder
How to Drop a car¿?¿?
01-03-2003, 11:10 AM
Fear the 1's and 0's
with that body youd have to make the mounting slots in a new place and probably dremel out those wheel wells.
**god that body is ugly**
01-03-2003, 11:11 AM
I are smart....
Lift car high in the air and release
Ok, seriously, you can also lower the body on the frame by cutting new slots in the shell.
01-03-2003, 12:45 PM
Got RiCe??
or
shave off the tip of the front tab and super glue another piece of plastic under.....
01-03-2003, 01:17 PM
smoove operator
Take a look here
Basically what SiK_pNoi_sTyLez said, I just put up small tutorial w/pics HERE for front modification. Then for the rear you need to Dremel out a new slot, sorry no pics yet  .
01-03-2003, 02:42 PM
01-04-2003, 12:34 AM
Do the tab thing, thats what I did with my Skyline. Shanly did the small rear wheels mod, which looked like ass and you can't use other gearsets without modding them as well. Also, don't lower the back, lowering the front by 2 layers of plastic makes the car look level and slightly tucks the front wheels, giving the ideal drop distance.
01-04-2003, 07:34 AM
smoove operator
That is only half true (for the bodies I use anyway), the Skyline body sat level w/ a single tab mod in front and a soft suspension set-up. If you Use a stiffer suspension set-up I can see how that would NOT have the same results, the body drop would appear to have little affect. Therefore you would need to do a double tab mod. Now in the case of my FD body, the single tab w/ the soft suspension is much lower in the front giving it a "hammered" look. So for this body I will do the "rear slot mod". As I said it's just my situation, so everyone may experience something different.
01-04-2003, 01:41 PM
Lets Play Some Tetris
if you dont want to do any shaving you can get a credit card (old one) and cut it into strips and glue them on to the bottom edges it looks either shaving or adding
01-04-2003, 04:47 PM
Got Mini-z?
or u could buy a k.i.t car..then put your body on its chassi ...the car wont run but its great for show
01-04-2003, 05:38 PM
are you kidding?? the K.I.T racers are fast as hell! for two bux what more can you ask for?? for straight,drag runs, kits are the way to go
