Old 01-02-2003, 12:27 AM
guy121 guy121 is offline
Accidently put the batteries the wrong way
Did I fry my bit? I was doing the dual mod, but didn't realize that the batteries were supposed to connect negative to positive, from the recharge tabs that connect to the pcb.
Now I can't seem to get the car to do anything. The car has a circuit now and I can recharge the batteries. Did I fry the batteries?
Old 01-02-2003, 12:31 AM
tory_103 tory_103 is offline
Sangru Lava U Sangru
Send a message via AIM to tory_103 Send a message via Yahoo to tory_103
sounds like it to me......... lol
you can charge a battery with it now, but will the car run off of it? or did you fry the PCB also?
Old 01-02-2003, 02:51 AM
shocon2k
If you connected positive to positive and vice versa then you didn't increase to 2.4 volts, you merely doubled your capacity at 1.2 volts. You didn't fry anything, however you may have if you tried charging your dual capacity 1.2 volt battery with 3.0 volts (like you're supposed to for a dual battery car).
Old 01-02-2003, 04:28 AM
bitspecialties bitspecialties is offline
I recently had the same problem on a single cell bit. 2 clones had opposite battery positions and the batteries seemed to be fried. Charge the batteries individually, pop them out and connect them up to a volt meter. I found that the batteries werent damaged, but charging them "backwards" almost de-charged them. But shoconn is correct, if you hook the batteries together in series then you are not doubling the voltage, just increasing the run-time / capacity.
Later.
bitspeC
Old 01-02-2003, 11:23 AM
Craig Craig is offline
Actually that’s Parallel not series. Connecting them positive to negative (Series) doubles the voltage. Connecting them positive to positive (Parallel) keeps the voltage the same but increases the capacity.
Craig
Overview On Lithium Ion Batteries moebrown20 XMODS Mods and Projects 19 05-02-2005 08:00 PM
Alkaline vs. NiMH (long) georc Bit Science 6 12-27-2002 12:59 PM
can u put dual batteries in microsizers zombiebaby Bit Char-G / MicroSizers 7 12-09-2002 11:57 PM
Dual Batt. Mod stevensmd3 ZipZaps 13 11-16-2002 03:03 PM
