01-01-2003, 08:17 PM
IRON MAN OF BIT RACING
MY Atari Bit Controller
Although im not the first to do this i just wanted to show it off it feels better when driving around and it doesnt make that annoying clicking noise anymore but it is very tight inside the controller Here are the pics
MY NEW CUSTOMIZED BIT:
red ae86 with zipzap spoiler
carbon fiber hood
3.8 motor (well, it doesnt want to run now)
qfm springs
back wheels on front and back
8.25:1 gearing
rare earth magnet steering
01-01-2003, 08:18 PM
another:
carbon fiber hood
qfm springs
8.25:1 gearing
01-01-2003, 08:19 PM
last one:
carbon fiber hood
qfm springs
8.25:1 gearing
01-01-2003, 08:57 PM
TinyRC Padawan
hey blacksabbath,
i was just noticing sig; do u have pix of ur AE86 posted somewhere?
btw, nice job on the controller. I went out and bought several booster kits
Bit Char-G Garage
Subaru Impreza WRX [Blue and Black]; Project D; Nissan Skyline GT-R set; Mazda RX-7 FD [blue]; Mitsubishi Lancer Evolution VII [Yellow and Rally Color]; Toyota Supra [Silver and Castrol race Color]; Auto-Modellista set
01-01-2003, 09:29 PM
yea
here you go http://www.tinyrc.com/forums/showthr...USTOMIZED+AE86 this also has pics of my telescopic antenna booster controller and my dual cell car
carbon fiber hood
qfm springs
8.25:1 gearing
01-02-2003, 12:42 AM
www.d1gp.com
with all these custom controllers, i keep thinking about the range on that, because the antenna isnt up..
so ...how the range?????
anyways, that controller rocks...old skool baby
01-02-2003, 02:54 AM
now you should design some sort of a belt clip so you can put it somewhere when you control it with the joystick. you could use an old cellphone case or something. Just an idea of what i would do.
01-02-2003, 07:58 AM
Im a cat, miow.
An idea for the antenna -------
1. Run a wire from the controller pcb antenna point to the
controller plug,
locate an unused pin,and solder that there,
2. Now on the controller plug, u solder a wire(this will be the antenna)to the corresponding pin of where u just soldered.
3. Twirl this wire around the joystick wire.
4. You now have an auto plugin aerial when u plug in the joystick!
So what do u lot think?
Post it!
01-02-2003, 08:07 AM
Hulk smash!
Good stuff blacksabbath070!
If you could post the steps you went through to put that configuration together, I'd love to promote this thread to Bit Science.
Thanks.
01-02-2003, 01:06 PM
instructions:
well first i got the idea off this thread: http://www.tinyrc.com/forums/showthr...ari+controller one of the links on that thread provides a picture of the pins color coded to understand which wire goes where ill attach the picture on this post then i took the housing off of the 9 pin joystick port and made sure the wires are on the right pin then i soldered the wires from the correct pin and soldered them to the correct position on the pcb after that i marked what plastic i had to cut out for the port to fit in the controller and i cut away i also marked where the screw holes were melted holes for the screws with a small screwdriver and put it all back together this mod is also much easier then it seems
carbon fiber hood
qfm springs
8.25:1 gearing
01-02-2003, 01:18 PM
Hulk smash!
Ahhh, already done and in Bit Science.
Oh well, I like your diagram better anyway!
01-03-2003, 06:06 PM
Ultimate ZZ racer!!!!!!!!
Why dont you try to wire the charger in the joystick.
01-09-2003, 06:52 PM
Namuna...
is it possible to place my pics in the bit science thread on this controller mod like pics only?
carbon fiber hood
qfm springs
8.25:1 gearing
