Old 12-31-2002, 09:25 PM
bitpro
No Matter What I Do, My Bit Wont Go Straight!
well, it does only for about 1 meter, then it sways to the left. is it true that a bit cant go straight for more then a meter? i want to have a drag racer, so should i like glue the magnet to the front.
mmmm... someone help? and whats the best combo for drag racing. overall. gears, suspention, tires, motor.
and where do u get graphite?
and one more thing, does the impreza(45mhz) have cripple cap in controler? thanx
Old 12-31-2002, 09:38 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
you get graphite at hobby stores or hardware stores.
Old 12-31-2002, 09:50 PM
bitpro
ur bit always go straight? like even after 1 meter?
Old 12-31-2002, 09:53 PM
DakarV's Avatar
DakarV DakarV is offline
I'll think of something..
My bit goes straight unless it hits a bump on the floor on something. See if you have any hair or thread stuck in your front wheels.
Old 01-01-2003, 12:24 AM
Riven Riven is offline
<-Buying Electromag Coils
I made a drag bit and took out the magnets. i put a strait axle through there. However i could never change it back its butchered but it always goes strait
Old 01-01-2003, 08:48 PM
bitpro
when i put in my 3.0 with any upgrade gears, it makes a lot of noise, like a crusty kinda grinding noise. scartchy, u know?
when i put in my orange gears with a lower motor, it goes smooth, is it cause the 3.0 os so powerful it goes crazy with power to the gears?
Old 01-01-2003, 08:55 PM
Have u tried changing the gear on the motor? switching them out?
Old 01-01-2003, 09:44 PM
bitpro
yea, its ok, got it workin thanx man
Old 01-01-2003, 10:24 PM
JTM's Avatar
JTM JTM is offline
1 4M 70 1337 4U
Send a message via AIM to JTM
id suggest putting it in front of a playboy and showing what its missing out on by not going straight.
heh
Old 01-02-2003, 03:37 PM
bitpro
LOL!!!!!!! but whats changing the motor gear going to do?
I got a straight bit. Deadite Bit Char-G / MicroSizers 5 10-18-2002 09:26 AM
HELP! can not get bit to go straight? DaRkKeNHeArT Bit Char-G / MicroSizers 2 09-23-2002 11:22 PM
