Go Back   TinyRC.com > 1/24 and Smaller > Mini-X > Mini-X Parts and Hop-Ups
Old 08-12-2002, 11:40 PM
dgilpin dgilpin is offline
Micro cooling fan
I have a T-maxx which overheated constantly. I put in a small 5volt computer fan and it never overheated again. So, here is a pic of my attempt for the mini-x.
Basically parts I already had - pager size motor mounted on chopped-up heatsink from something. Bent the bottom of the heatsink to make it a press fit over the motor. Fan blade is just a piece of bent plastic! Motor is powered from the rx connector for the esc. Resistor added drops the voltage a bit.
Motor still gets too hot on the bottom, but at least now it cools down pretty fast.
Old 08-13-2002, 12:49 AM
tinyrc's Avatar
tinyrc tinyrc is offline
Cool! (no pun intended ) What kind of sink is that on the motor? I think I'm going to get some of those RAM sinks and see if they help at all.
Old 08-13-2002, 01:30 AM
I got it at a RadioShack a couple years ago. Not sure what it was for, I just needed some for a project. It was one of those Commercial Sales stores that has since moved out, but if I run across the old catalog I will look it up and post the info.
It was originally much bigger. What is left is about one fourth of it after using the dremel on it.
Old 08-14-2002, 09:37 PM
I ran it around at full throttle as much as possible on the concrete and smooth surfaces today, and I was surprised how much cooler it was. I could hold my finger on the bottom of the motor without feeling like I was going to get burned.
Originally I tested it on thick pile living-room type carpet. Apparently the dragging puts much more load on the motor, as it was hot after running with the throttle pegged for 5 minutes or so. But after standing for one minute with the fan on it was cool again.
It weighs almost nothing and didn't appear to affect the battery, so I will leave it in until it causes some other problem. It stayed in place after a few roll-overs and other crashes!
I saw mention of a "vented" motor. I wonder if drilling a couple holes in the can would allow air to circulate through the motor - even without a fan? Someone try it and let us know!
Old 08-14-2002, 09:58 PM
tinyrc's Avatar
Wow, that is really impressive! I'm going to have to try this myself for sure!
My Custom - Micro T + Case + Ramps nazcom_101 Micro-T General 8 11-30-2007 05:56 AM
How To Build a Micro Speed Control From a Servo Overlander TTTT 20 05-26-2004 01:21 AM
rtr hpi micro rs4. spy esc, 2 bodies, plus extras isk8blind For Sale/Trade 0 08-31-2003 05:38 PM
ZipZaps Ultimate Fan Contest at Zipzaps.com cj1267 ZipZaps 4 07-10-2003 12:37 AM
Canadian Micro Grand Prix lornecherry Bit Char-G / MicroSizers 9 10-03-2002 02:36 PM
