08-12-2002, 10:25 PM
LoWeReD
hown to you lower the chhassis of the Bit?
08-13-2002, 04:16 AM
TinyRC Chief
Remove the stabiliser bar. I didn't lower the chassis on mine, I lowered the body on the chassis.
08-15-2002, 11:18 AM
Hypnotic ain't she.....
the stabilizer bar broke off my car already
08-16-2002, 03:48 PM
yellow fish forever!
then its probably...lower?
08-16-2002, 03:54 PM
I luv LEDs
Don't take the stabilizer to lower your car. You'll get horrible handling.... The way to get a "lowered" look of the car is to put another set of rear wheels to replace the front wheels.
Another way is to lower the car is to lower the entire body.... Up to you on how to do that....
08-16-2002, 05:02 PM
oh, ok i think ill lower the body because i dont have another rear wheel
08-16-2002, 05:28 PM
how do u lower the body?
08-16-2002, 05:39 PM
SpeedFreak
you could make a body kit and make the car appear lower with epoxy putty. usually this is available at your lhs.
08-16-2002, 09:35 PM
I luv LEDs
One way of lowering it is to use a dremel and grind the slots where the chassis tabs go in.... grind them till you get the right height.... the rear is easy, but the front is a bit more tricky... then fill the unwanted gap with putty.....
08-16-2002, 11:52 PM
Shoot To ILL
you might want to buy one those stabalizer kits since your done went and broke off.... or buy some springs when QFM comes back
Custom:
Toyota Trueno
tires: soft
gear: light blue
shocks: mediums
motor: 2.2
08-17-2002, 02:42 AM
Moderator - Modifier
See the lowering mod at the QuestForMadness.com website. Click into the mod on the left hand side.
08-17-2002, 01:47 PM
k, ill do that, thanks.
08-29-2002, 10:56 PM
www.d1gp.com
does a lowerd ride improve performance any?...probably not THAT realistic to real life physics.....
08-30-2002, 09:53 AM
I luv LEDs
Nope, I don't think so. It just looks better.
08-30-2002, 11:49 PM
Just kinda burned you...
sooooo, lowering your bit is a bad thing for performance, yet it makes your but look cooler. am i correct?
"I won't lose, no matter what, because the prize is a full tank of gas." Takumi
