Old 12-31-2002, 01:39 AM
JTM's Avatar
JTM JTM is offline
1 4M 70 1337 4U
Send a message via AIM to JTM
dual batt mod w/o soldering to car.
solder two tabs onto the ends of the batt you soldered and pu ttape on the backs so theres that barrier between the tabsthen superglue the backs together.. now just slide that tab you made in between the contact and the neg of the batt.. now u have a dual batt bit. youll still have to mod your controller to charge it unless u have a stand alone.. wich is what i am going to use (a standalone) anyone have any ideas on moutnign the other bat inside so from the outside it looks like a normal bit?? ive tried cleaning out the chassis to fit two batts down inside with the other stock mounted one.. but there isnt enough room.. i tried useing a Bb but its just short a HAIR.. for now ill be useing a Bb and putting the batt on the deck in back.. ill show pics in a hour or so when i get it all mounted..
Old 12-31-2002, 02:19 PM
Al Hounos Al Hounos is offline
that sounds really cool and id like to try it but unfortunately your writing is terribly hard to understand. you think you could proof read a bit?
My Fairlady Z:
*rare earth*
Old 12-31-2002, 03:08 PM
tory_103 tory_103 is offline
Sangru Lava U Sangru
Send a message via AIM to tory_103 Send a message via Yahoo to tory_103
yea man, that sh!t is confusing as hell...... reword it and like if you could make some pics with MS Paint taht would be even better.......... l8r
Old 12-31-2002, 03:47 PM
bill's Avatar
bill bill is offline
I are smart....
Old 12-31-2002, 03:54 PM
JTM's Avatar
JTM JTM is offline
1 4M 70 1337 4U
ill take a pic of the parts i am talking about.. but basically youll end up with two loose wires like this
|_______________| a wire with a thin metal tab on each end. then you take one of of the wires and attach them together to make a tab u can slide in between the terminal and the batt.. insulate the backs so they dont contact each other.. now take the other ends and use electical tape or shrink wrap to secure them to the second batt. no risk of heating the cell and frying it. and no perm mods done to your chassis
Dual Batt. Mod stevensmd3 ZipZaps 13 11-16-2002 03:03 PM
dual battery mod no speed increase? delmonk Bit Char-G Mods and Projects 7 10-17-2002 12:10 AM
? about dual batt mod go_zz_go ZipZaps 32 10-15-2002 02:18 AM
