Old 12-31-2002, 01:32 AM
Riven Riven is offline
<-Buying Electromag Coils
Full Size Wheel Upgrade
I was noticing alot of slack in the stock wheels and looked closely and the plastic has wallered out some. i was planning on doing the full size with mod anyway so i took it a step further and came out with a GREAT end result.
I got on my metal lathe and made a cylinder with a .125 outter diamiter and drilled a .052 hole into the center. i made it from brass so it would not effect the magnet and its the lightnest weight thing i had around. i then drilled an 1/8 inch hole into the center of the wheel i was going to place onto the front. (Zip Zap wheels are the best because the hubcap covers the brass cylinder) i then centered and glued the cylinder into the wheel. after drying i had aperfect fitting no slack wheel that will never wear out. the brass isnt visible at all unless u turn the wheels and really look close. the hadling is much better. there is WAY less drag with the cylinder spinning on the pin than the plastic spinning on the pin. when oiled it is outstading.
The only draw back is all the holes HAVE to be EXACT in the center and strait. i used a mill to make sure all holes where strait. But all in all its an easy thing to make.
Old 12-31-2002, 01:34 AM
I forgot to mention i am also going to be making some bushings for the steering arm to help there also but i have to get a sharper tool first since it will have to be a VERY thin bushing
Old 12-31-2002, 02:47 AM
shocon2k
Are you at college? I have a class in our machine shop and I was considering making some parts on the lathes. A lot of the kids here are in middle or high school, so you might be able to mass produce these things and sell them for like $4 a set to a lotta kids on here, especially if they work well.
Old 12-31-2002, 03:03 AM
im in college but i have a lathe at home. i thought about that but the hardest part is drilling the holes in the wheels and they would ahve to do that the little bushings are easy
Old 12-31-2002, 04:58 AM
shocon2k
Lathe at home....I envy you....
looking for full size wheel mod BCG/MS ucfdan Bit Char-G Parts and Hop-Ups 3 09-02-2003 08:54 PM
looking for info full size wheel mod for BCG/MS ucfdan Bit Char-G / MicroSizers 5 07-07-2003 10:17 AM
full size wheel mod question Kaizer-Stryke Bit Char-G Mods and Projects 1 01-02-2003 06:01 PM
full size wheel mod.. Need4Speed210 Bit Char-G Mods and Projects 2 10-20-2002 01:28 PM
Full size wheel mod Legion Bit Char-G Mods and Projects 6 10-09-2002 01:31 PM
