Old 12-28-2002, 10:30 AM
jutte07 jutte07 is offline
Send a message via AIM to jutte07
Omg Look Here Any One That Knows Anything About Zz!!!
I was racin my zz on the ground and then it wouldnt turn so i took off the cover and two of my lil copper wires got somehow unhooked, but they both go to the same spot...so i tryed sotering them back to the soder, but it still doesnt turn at all! Can anyone help me???
Old 12-28-2002, 01:57 PM
bagelbm bagelbm is offline
Send a message via AIM to bagelbm
I've *heard* that those wires are very delicate, I don't know if they can be re-attatched.
ZipZaps:
Red Mustang[ 27 mhz, Turbo/GreenGears]
Yellow Mustang[49 mhz NOS/ +Headlights]
FF Upgrade Kit/AmericanBodies UpgradeKit
Old 12-28-2002, 03:45 PM
Bus Driver!
Hum...
First are you sure its that point? There are a lot of points on that board. If you are sure then you need to check some stuff.
Do you have a voltmeter with ohm function. It could be the coating on the wires is still there { JUST A LITTLE NOT THE WHOLD THING! }
As always this is at your own risk...
If you have a meter with ohm function try the following.
1) Unsolder the point you solder to.
2) Put one probe on those wires.
3) Touch the probe to where the two seperate wires tie onto the board.
4) If you see it go from infinit to a low ohmage then its something else like wrong point otherwise the coating that keeps the coil wire from shorting is not allowing a connection.
If you get no reading then you will need to remove a very tiny bit of the coating on the wires. A knife will do but a small pice of sandpaper is better. JUST ENOUGH to connect to that point on the board where they went before. NO MORE.
Omg!!!!!! jei$ Bit Char-G / MicroSizers 14 01-20-2003 08:17 PM
OMG, Look at these roads!/!/! ZBsk8r Bit Char-G / MicroSizers 7 11-12-2002 09:05 PM
Omg dumboi07 Bit Char-G / MicroSizers 1 10-17-2002 11:19 PM
