Old 12-28-2002, 04:30 AM
scottyboyfun's Avatar
scottyboyfun scottyboyfun is offline
Im a cat, miow.
Send a message via Yahoo to scottyboyfun
Best Lightest LED MOD!
This is how I did my LED foglights for my Honda S2000!
I purchased some blue SMD LEDS (surface mount, these are tiny, weight next to nothing and are used in mobile phones mainly).
1. I cut the foglight holes out from my shell, placed the SMD LEDS in the holes
2.Held them in place with blue-tak
3.Soldered the enamelled wire to the SMD LEDS, and wired them in parallel to a small 3V Lithium cell.
ENAMELLED WIRE MUST HAVE THE ENAMEL TAKEN OFF THE ENDS BEFORE IT WILL MAKE A GOOD JOINT, OTHERWISE U MAY FIND 1 LED IS SLIGHTLTY DULLER THAN THE OTHER!
THERE U GO, LIGHTWEIGHT LED FOGS!
THE HEAVIEST THING IS THE SMALL LITHIUM CELL, BUT U CAN WIRE IT TO THE CAR BATTERY INSTEAD IF U WANT.
So what do u lot think?
Post it!
Old 12-28-2002, 04:33 AM
Im a cat, miow.
I THINK I MIGHT GIVE IT ICE WHITE HEADLAMPS TOO, POSSIBLY UNDERBODY NEONS!!!!
OR MAYB SUM1 COULD MAKE BODY VENTS, CUT HOLES FOR THEM, THEN HAVE THE LIGHT COMING THROUGH!
Post it!
Old 12-28-2002, 06:55 AM
tarnjit tarnjit is offline
will they work off the car battery!! if they do u might even be able to join it at f and b to make it come on and off when u go back and farward
Old 12-28-2002, 03:25 PM
Im a cat, miow.
The Forward and Backward connection would stop the battery from being discharged as well! n no extra battery weight!
It'd wouldn't affect the car weight wise then!
As long as the leds dont sap up the motor power then - greaat!
Post it!
Old 12-29-2002, 02:53 AM
dikpik
how exactly did u cut out the fog lights?
i just cut mine out as well, but its a total mess... thje whole front of the body is scratched up.. and im bleeding!
Old 12-29-2002, 09:56 AM
ClockwOrk ClockwOrk is offline
A good plastic / acrylic drill bit is the best way to bore holes in the body IMO. It also helps if you have something to hold the car in place while your doing it to keep it steady!
- ClockwOrk -
Old 12-29-2002, 02:33 PM
Im a cat, miow.
I actually used a stanley knife, as iI have a steady hand, BUT!!!!! Do what clockw0rk said, its the best way!
Post it!
Old 01-06-2003, 09:01 AM
Im a cat, miow.
Heres the wiring pic
Post it!
Old 01-06-2003, 09:04 AM
Im a cat, miow.
front
Post it!
Old 01-07-2003, 01:40 PM
evileric evileric is offline
MSN:eric_exec@hotmail.com
sick sick sick...
LED Mod - Flash to pass (Get your minds out of the gutter). X_I_Ted Bit Char-G Mods and Projects 6 07-02-2003 06:03 PM
Led Mod Problems pakiplaya Bit Char-G / MicroSizers 1 12-18-2002 05:31 PM
Assistance with LED MOD please help a newbie SmokenRubber Bit Char-G / MicroSizers 0 12-04-2002 04:02 AM
LED Mod Spitfire7001 ZipZaps 13 10-12-2002 11:55 PM
