Go Back   TinyRC.com > 1/24 and Smaller > Auldey / Radi-Can > Auldey (All)
Old 12-26-2002, 12:06 PM
hunter hunter is offline
Send a message via AIM to hunter
Turning Problem
This problem is annoying. When i put new wheels on my car. i lost my ability to go straight. before the new wheels when i turned. then stopped turning it would go back to straight. now it just stays nwhere it is. if i'm going right it stays going right.
Old 12-26-2002, 04:23 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
ok heres the deal...
a) you either lost your steering spring while assebling it back together
b) you assembled it incorrectly
open your steering cover back up...and chek to see if the metal spring is still there....
it is is, then your problem is B
when u dissasemble the steering, the magnet gets loose, as does the steering spring....
the bottom of the magnet has 3 pegs ...when placing them back into your car they must be vertially aligned.....
the top peg should be IN THE MIDDLE OF THE STEERING SPRING
the middle peg should go in the large hole at the end of the steering spring loop
and the last hole should go in the steering arm...uh white part thingy im not sure what its called
anyways, try that, if not then u have to realign your magnet
Old 12-26-2002, 06:13 PM
how do u do that
Old 12-26-2002, 06:18 PM
what way does the magnet face show me a pic??
Old 12-26-2002, 08:08 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
http://uk.geocities.com/cannedterrors/tips.htm
look at the 2nd tip on this page, it has 3 pictures...
just follow what they say...
this page also has ummm "robots" made from auldey parts to fight each other in the gallery and other ...*shrug
Old 12-27-2002, 06:37 AM
ur a genius
Old 12-27-2002, 04:50 PM
it didnt work
Old 12-27-2002, 07:14 PM
buzzkill buzzkill is offline
Send a message via AIM to buzzkill Send a message via Yahoo to buzzkill
steering issue
i had this same issue after i modded my car, i had to pull the front end off again. when you take the front cover off and look at the underside you'll see the imprint of the magnet, "the little circle guide for the magnet to rest in", any way what i did was take a drill to it and widen it out, the when i reassembled it made sure my wires that go to the magnet where no being snagged under the circuit board, they need some slack. after that i moved the wheels back and forth by hand to make sure it didn't get caught up on anything.
this seem to work my steering no longer gets stuck..
Old 12-28-2002, 10:22 AM
thats not my problem my wheels dont like flicker back. when you turn there supposed to flicker back straight. but they just stay turning
Old 12-28-2002, 11:53 AM
wheel turning
my wheels didn't flicker back either...... thats how i fixed mine..
Old 12-28-2002, 05:26 PM
ill try it
Old 12-28-2002, 08:27 PM
still not working
Old 12-28-2002, 09:24 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
doooode
chek to make SUUUURE that you have the peg in between the spring...dont put i on top, or make it cross over....
u also have to realign your magnet every time u take it apart..
to do this,
after you place your spring and magnet peg thingy correctly, you have to turn your magnet in place until u see it slightly move the spring to one side, when it snaps back press your controller to see if it is turning in the right direction......if not, keep turning your magnet in the same direction untill it snaps back again..it should work.
Old 12-29-2002, 12:28 AM
slotsurfer's Avatar
slotsurfer slotsurfer is offline
VILLAGE IDIOT
MTL said:"when u dissasemble the steering, the magnet gets loose,
the bottom of the magnet has 3 pegs"
MTL the part you describe as the magnet is not the magnet it is the steering motor/ Rotor that turns the car.The Magnet is the Ring.What might be the problem is you need to make sure the slot on the bottom of the ring magnet is sitting on top of the White steering adjustment peg.Then you will have the correct poliarty so the steering rotor will steer the car.MTL did describe the correct assembly of the steering.He is just little mixed up on what each part is called.Check out Tinracers.com in the dowload section and download the comprehensive manual and it will show you the correct way to work on your car with lots of photos.
Slot Surfer
VULCAN RING SLOTCAR RACING
I get my news from the daily show with John Stewart the #1 fake news man in the USA
Old 12-29-2002, 07:06 AM
forgot about that i will try it
Second Mustang With Steering Problem: Totally Depressed Stever1960 XMODS 2 12-17-2005 07:03 PM
Unequal Right and Left Turning Radius Fix backtrack9 XMODS Mods and Projects 20 10-02-2004 01:32 AM
help, turning problem ben1112 Mini-X Parts and Hop-Ups 5 02-15-2004 06:22 PM
sputtering problem with my new zap... Cool Dad ZipZaps 12 06-20-2003 11:05 PM
