12-26-2002, 10:06 AM
Digi-q style dual motors with Bit PCB?
Is it possible to rewire a bit char-g to run dual motors with differential steering, like in digi-qs? Dual motors by itself isn't difficult; you just need to wire two in parallel. But how can steering be added in to slow down the L and R motors using the L and R output from the PCB? I suspect the digi-q uses a different style PCB with 2 speed controllers, but if it is the same PCB as found on www.tapspring.com, it would be as simple as finding a diagram of how the digi-q is wired. Does anyone know if this mod is possible? Thank you.
-M.
12-28-2002, 11:46 AM
Bit Obessed...
you can try doing what I did to my canned heat, but the bad thing is that you have to control the motors independently, so that means you can press forward and back, but each motor has its own forwards and back.......
Anyways, what you can do is rewire it so that L/R control one motor while F/B controls the other.
Oh, and another thing is..........you might have to check to see if the L/R gives as much power as F/B.........
12-28-2002, 11:48 AM
Bit Obessed...
