Old 12-25-2002, 08:06 PM
DavidDeLaurier DavidDeLaurier is offline
Send a message via AIM to DavidDeLaurier
2.4 Volt Turbo Charging Question...
I just set up my 2.4 Volt Mod on my new WRX. I also have a 3 Volt charger set up to charge it. My question is about my run time. I charge it on the charger for exactly 2 minutes, but when I run the car it only goes for about a thirty seconds of super speed then drops to super slow. Why does it do this? Do I need to charge it longer? Do I need another, bigger charger?
Any help would be great!
Old 12-25-2002, 08:26 PM
Does anyone know???
Old 12-25-2002, 08:42 PM
Please, somone out there.......
Old 12-25-2002, 09:13 PM
TemjinNeo78's Avatar
Bit Drag Racer
try more volts....and cut down that charge time to abou to about 1minute
Old 12-25-2002, 10:19 PM
Now I got it to run a minute for every minute I charge it. I will try a 9V as my charger. Maybe it will work better. If I use more volts will it go longer with a shorter charge?
question about turbo fets pimpjuice XMODS Parts and Hop-Ups 0 01-28-2004 09:57 AM
layman's tricell charging question Snow Bit Char-G Mods and Projects 0 11-28-2003 06:06 PM
Another Charging Question Buzzbait Epoch RC1/43 2 05-03-2003 02:17 AM
Semi-technical charging question extremeR1der Bit Char-G / MicroSizers 6 04-30-2003 11:36 AM
electrical question about charging..resistor values..limiting current.etc Clint Bit Char-G / MicroSizers 17 03-07-2003 02:49 PM
