Old 12-24-2002, 02:06 AM
shocon2k
Green Gears (3.43:1)
I have a set of 3.43:1 green gears. My 2.6 cannot provide enough juice to get them turning. I will eventually do dual batteries, but using only one battery, is there any way I can use this gearset practically? It seems wayyyyy too low a gearing to be useable.
NOTE: if you connect the battery directly to the motor it will spin them up real fast, but the PCB on my car limits the amperage and voltage enough so that my 2.6 can't start up. Also, the mesh is awful in my Microsizer, its fine in the car it came on, the Hot Wheels KIT Racer.
Old 12-24-2002, 07:27 PM
shocon2k
Come on, 31 views and NONE OF YOU KNOW how to use these and have the car still be driveable?
Old 12-25-2002, 12:53 PM
zclonedude's Avatar
zclonedude zclonedude is offline
i've no idea whats goinon
sounds like you need a motor with more torque try a 1.0 or 2.2 if you have one laying around, hope that helps.
good luck!!!
Old 12-25-2002, 01:17 PM
JBit's Avatar
JBit JBit is offline
go Go GO, JBit Mifune!
make sure you are using the WHITE pinion gear - the one that you attach to the motor itself. the motor probably came with the black one, which wont work. get any bit racer replacement motor (my 3.0 came with a black one and a white one) and put the white one on - it will turn your bit racer pinion gear.
The Mach w/DKS 3.4 Darkside Rotor.
Old 12-25-2002, 03:17 PM
shocon2k
I am using the white pinion that came with it, and I have a 2.2 that can't turn it either. I'm hoping dual batteries will remedy this...but who knows. Anyone out there successful with super high gearing?
Old 12-25-2002, 03:42 PM
takumi_drifto's Avatar
takumi_drifto takumi_drifto is offline
DriFt OnLi
Send a message via AIM to takumi_drifto Send a message via Yahoo to takumi_drifto
wow that sucks... i dont get why they wont turn tho.. i would think 2,6 have enuff power to turn em.
DriFT_
Old 12-25-2002, 09:07 PM
TemjinNeo78's Avatar
Bit Drag Racer
try the zip zap motors(NOS and TURBO) i have these gears and they have great top speed compared to the bit motors. If youy try the 3.0 and up you will have horrible acceleration and top speed.
Old 12-25-2002, 09:14 PM
tifosi_ms1 tifosi_ms1 is offline
I can't get a 2.2 to pull 3.43. Get a 4.57 that will pull well (I have one) very steady accel. Great for draging.
Bit Char G, Blue Skyline GT-R, 2.6 KIT
Microsizer, WRX won microsizers.com
Micro Q, F360 Modena, Working on it
Castrol Supra Body, Mobil Nsx Body
Old 12-25-2002, 09:53 PM
shocon2k
Looks like I'm picking up another KIT racer....
Old 12-26-2002, 09:46 AM
jei$'s Avatar
jei$ jei$ is offline
you see i had a similar post
payaso said take it off
so i did.
its the same example in a real car
look at it this way
ur driving a "stick"car
like shocon's civic
when u upshift, the gears in ur transmission
get smaller
SOooooo.
the idler gear stays the same but as you
shift up, the axle gear gets smaller
so as the idler gear turns at the same ratio,
as the revs get higher, u will want to upshift
which causes the axle gear to get smaller,
so with the smaller gear attached to the axle
the wheel will obviously turn more.
hehe
dont take my advice if i dont wan too
lol
A man who desired nothing is invincible.
Old 12-26-2002, 10:25 AM
mattattack mattattack is offline
strange ... i have the green gears and a 2.6 motor and im using the plack pinion. and it works just fine
[IMG]
Old 12-26-2002, 11:41 AM
scottyboyfun's Avatar
scottyboyfun scottyboyfun is offline
Im a cat, miow.
Send a message via Yahoo to scottyboyfun
Use the gear which originally came on the car for the new motor.
So what do u lot think?
Post it!
Pinon gears. dje7447 Bit Char-G / MicroSizers 7 10-09-2003 03:52 PM
Tips for quieting gears NoPropMan Bit Char-G / MicroSizers 14 03-27-2003 11:59 PM
K.I.T. gears = stupid Zephyranthes Bit Char-G / MicroSizers 4 03-14-2003 12:59 AM
WTB/T for gears big-key For Sale/Trade 0 03-06-2003 12:19 PM
clone gears vs bit gears ? Mike the Great Bit Char-G Parts and Hop-Ups 10 01-19-2003 01:05 AM
