Go Back   TinyRC.com > 1/64 and Smaller > Yokomo Puchi Maru > Yokomo Puchi Maru Gallery
Old 08-08-2002, 09:45 AM
usagi's Avatar
usagi usagi is offline
a few
here are a few pictures
Old 08-08-2002, 09:46 AM
usagi's Avatar
another
Old 08-08-2002, 04:31 PM
tinyrc's Avatar
tinyrc tinyrc is offline
usagi, welcome to the Forums, and thanks for posting these!
Old 08-08-2002, 10:33 PM
usagi's Avatar
No problem, I wil be coming around alot more. I be taking the body off and showing you the insides some time soon. Nice place you have here.
Old 11-27-2002, 06:12 PM
hally hally is offline
inside
hi usagi sama
you wanted to show the inside of a puchi maru.could you open it for me give it too me please please
Old 12-05-2002, 09:47 PM
dgilpin dgilpin is offline
hally,
usagi mysteriously vanished! But here are some pics I took of mine a while back.
http://www.gcs-net.com/puchi/
Old 12-09-2002, 03:23 PM
chech doesn't look rigid and they should use faster motors i think a 4mm coreless motor shold have enough power for steering and a 7mm coreless motor is faster and stronger
they need less room and are more powerfull
the car is expensive enough with that mabuchi m10 ****motors
Old 12-09-2002, 06:26 PM
The front-end shot is the steering mechanism taken off of the chassis, which extends out in front of the tie rod. Then it attaches to the body with a screw. So it should be plenty rigid.
Steering is very quick, but it would be nice to have alternate drive motors. Can you drive a coreless motor off of a standard speed control?
Old 11-30-2003, 01:58 PM
strakka's Avatar
strakka strakka is offline
AA member
Send a message via ICQ to strakka Send a message via AIM to strakka Send a message via Yahoo to strakka
i know this is a really old post... but where can i get these motors... 4mm coreless motor & 7mm coreless motor
Old 11-30-2003, 02:41 PM
coreless motors ...
DWE: <http://www.smallrc.com/dwehtml/iemicro.cfm>
Indoor Flyer: <http://www.indoor.flyer.co.uk/index.htm>
Homefly: <http://www.homefly.com/>
Micro R/C: <http://www.microrc.com/WES.htm#coreless>
Old 11-30-2003, 05:11 PM
strakka's Avatar
AA member
sweet! thanks man
Old 12-01-2003, 10:00 AM
No problem - I already had those bookmarked.
Let me know if you try a new motor.
One of my Puchi Marus now has MicroSizer front and rear wheels and tires (and bigger wheel wells on the body), a Mini-Z receiver, and runs on a LiPoly cell. No more twitching and very fast! It is easy to flip over if you turn quickly. I just wonder how long those tiny gear teeth will hold up under the added stress.
No motor mods yet, though.
Old 03-30-2004, 07:35 AM
JackD JackD is offline
ITCOB
Can you post a pic of your puchi with the MS wheells ????????? I don't run my puchi much because of the little wheels..
Old 03-31-2004, 09:15 AM
I should have taken a picture, because it is all apart right now. I am trying to make either a lexan or resin cast body, and use either dub city wheels or the german aluminum wheels (still waiting on tiny). Maybe foam tires, if I can. My experimental foam tires on the bit rims did wonders for the puchi, as they provided a bit of suspension action. Very hard to make that small.
For the bit wheels, I did have to dremel the wheel wells out - mostly in the rear. It did really look and perform much better, but were not perfect. The rear rims had axle holes too large. That made them hard to get centered. The front seemed to have a little toe out for some reason, which I didn't want at all. That is why I am starting over with the dub city rims this time.
If it turns out good, I will post a picture this time.
