Old 12-21-2002, 06:31 PM
scottyboyfun's Avatar
scottyboyfun scottyboyfun is offline
Im a cat, miow.
Send a message via Yahoo to scottyboyfun
Faster Steering?
Is there a mod we can perform to give the steering more power, so it will respond more, esp as i have a twin ni-hm!
At high speed the steering doesn't seem to steer much!!!
Can we get more power to the steering coils?
So what do u lot think?
Post it!
Old 12-21-2002, 09:00 PM
MicRoMaN's Avatar
MicRoMaN MicRoMaN is offline
Microman to the rescue!!!
You can try a rare-earth magnet not sure if that would help though.
-----My Mini R/C Site-----
Old 12-21-2002, 09:08 PM
TemjinNeo78's Avatar
Bit Drag Racer
dude
when u do that to ur bit(dual batts) you will ave to cope with serious steering loss(more like a drag racing)
Old 12-21-2002, 10:51 PM
IznastY
I gave up trying to make the steering good on my car after i installed the dual bat's :\
Old 12-22-2002, 12:31 AM
Subie Driver Subie Driver is offline
'00 Subaru Impreza 2.5 RS
Make the car extra fast or rear-heavy, and there just plain isn't enough weight on the front tires for them to grip. They are probably turning fine, they are just slipping instead of gripping. Maybe you could try adding some weight (non-ferrous weight, or it will interfere with the steering) to the front of your car and seeing if that helps any.
27MHz Microsizer White Peugeot 206: 3.8, NiMH
49MHz Microsizer Yellow Lancer Exolution: stock
27MHz LXX Char-G Xanavi Skyline GT-R: 3.0
27MHz ZipZap Yellow F&F Civic: 2.6, Carbon Fiber-look hood, lowered, sport tires, turbo gears
Old 12-22-2002, 11:45 AM
Im a cat, miow.
I know what I can do!!!!
Take the front suspension out!
Then there will be more weight bias towards the front!
Post it!
Old 12-22-2002, 03:20 PM
IznastY
Ok this is what i did, using double sided tape i mounted the battery in front of the car (where the front window is) i had to cut out the window with my xacto nife but it works. the front wheels dont leave the ground now, no more wheelies.
Edit: Just make sure u dont take the turns to fast, car will still flip
Old 12-22-2002, 06:42 PM
Im a cat, miow.
Why won't my car wheelie?
Is it the positioning of the cell do u think? or cos its only got a standard clone motor,in a dual cell oem?
Post it!
Old 12-22-2002, 06:55 PM
Put a 3.8 in there, and I'll bet it will wheelie!
Old 12-22-2002, 06:58 PM
Won't the front drag on the ground if you do that? Might not, guess it depends what car you have. Just looked at my Microsizer, and it would still clear, but my cheap-ass Cannonball clones would drag without front suspension.
Old 12-22-2002, 07:05 PM
Im a cat, miow.
It clears the ground by 2 mm!!!!!
Post it!
Old 12-23-2002, 12:04 AM
Swe
Have you tried to run backwards and then forward?
Do the backwheels spin?
If you have a 1.0 or 1,6 it wont probaly spin because theese motors is to slow
Old 12-23-2002, 04:56 AM
Im a cat, miow.
Im not sure what it has!
Its faster than the motor in my tomy, which has a yellow end and is a honda s2000 40 mhz.
The Clone I have is a panther, it was faster than the tomy 2 start with, and even faster when i put the w ni-mhs in it.
If u look at my pic then mayb my cell is not far enough back 2 make it wheelie?
: bdrop:
Post it!
Ideas on how to increase steering power mde Bit Char-G / MicroSizers 4 05-01-2004 02:42 PM
WOW, another steering discovery! Upgraded steering motor! cyborgzero ZipZaps SE 2 02-22-2004 12:16 PM
Better steering and faster bit. bwsk8 Bit Char-G / MicroSizers 17 04-27-2003 10:44 PM
More powerful steering for 2-cell mod? bonus: faster charging for dual battery mod Chris Bit Char-G Mods and Projects 1 11-23-2002 07:24 PM
