12-20-2002, 01:58 PM
Help! my wheel mod problem!
I took all the time to do full size wheel mod and took it for a test drive and the tires get stuck on the chassis when I turn. has anyone else had this problem? How did you fix it?
12-20-2002, 04:06 PM
Tech-Ninja
I did the mod on an LXX and had the same problem. It don't think there can be anything done to fix it. I swapped the wheels and put them on a Z-car, which worked, but I broke a steering knuckle doing it and the LXX or clone knuckles are slightly longer.
Guess I'll be buying another Z-car for parts.
12-20-2002, 04:26 PM
Sangru Lava U Sangru
I've run into a similar problem like this..... except it happens to me when i put Hot-Wheels bodies on a bit...... i simply file down the corners of the fenders, but not too much to where you can see it very well.......... works for me, but Hot-Wheels bodies only cost $1..... im sure you wouldnt want to do this to your more expensive body, but you gotta do whatever it takes bro...... good luck
12-20-2002, 09:18 PM
I are smart....
Here you go, i ripped the pic from the above link
12-20-2002, 09:27 PM
Keep plodding
That looks like a Dremel tool fix to me. It would give it a cleaner look than melted plastic. Just a thought.
There is wisdom in a multitude of counsellors.
12-20-2002, 11:33 PM
yellow fish forever!
unless you are really good, dremels make your chassis look like something tried to messily devour it.
thats alright though, its underneath the body, and you will have a working car.
12-21-2002, 12:09 AM
mogi's godfather
dremel
just use a fine sanding disc
at low speed on the dremel
go easy and just take it down
a little at a time
works good
oink
12-23-2002, 03:46 PM
How do you get the pins (axles) out of the steering knuckle.
See Ya!
12-23-2002, 11:11 PM
mogi's godfather
very carefully
i tap them out
gently with a small nail
i drilled a 1/4" whole in a scrap
of plywood
and center the knuckle
over it so the axel falls
through
go easy so you don't
crack it
oink
