Old 12-20-2002, 11:20 AM
jayd177 jayd177 is offline
Track slip problems
I'm having annoying problems with the panther and the sherman. The drive-wheel on both of those are smaller then the russian and the tiger. That leads to slipping between the track and the drive-wheel. Especially my sherman. The track on one side is too big a circle and so on super-turns the track slowly comes off.
Anyone have any ideas??
If nobody else has a better idea, I think I'm going to try the second to last mod on this page:
http://www.geocities.jp/s_lx60/cd/make.html
It shows someone modifying the drive wheels for more grip by glueing little spurs to it. Thanks, Jay
Old 12-20-2002, 12:28 PM
BillyBonz's Avatar
BillyBonz BillyBonz is offline
Jay, I had the same problem on my T34. Check out this Post:
http://tinyrc.com/forums/showthread....&threadid=3235
I was trying to stop the slipping of the tracks and tried heat shrink, the foam rubber donut and here is what worked. I painted a rubberized roof coating on the drive wheel. It's a black, gritty kinda substance and it's water based so it is plastic safe. It's called Recycled Rubber Roofing. I originally bought it for making a track for my Bits. I has a look of asphalt when it dries. It didn't work well for the Bit race track because it was too lumply. It did work on my tank after I thinned it out with some water. I am thinking about trying some of that rubber\plastic coating called Plasti-Dip. (plastidip.com)
Here is a crappy pic of my drive wheel.
Old 12-20-2002, 04:31 PM
Those are excellent ideas. I'll give it a shot and see what happens. Thanks, Jay
Old 12-21-2002, 01:45 AM
slotsurfer's Avatar
slotsurfer slotsurfer is offline
VILLAGE IDIOT
I have a question where are we going to get replacement track for are tanks when we where them out?
Slot Surfer
VULCAN RING SLOTCAR RACING
I get my news from the daily show with John Stewart the #1 fake news man in the USA
Old 12-21-2002, 04:20 PM
Hey Billybonz,
Can you tell me where you got that water based paint-on rubber stuff?? Thanks a lot, Jay
Old 12-21-2002, 08:31 PM
BillyBonz's Avatar
I bought it at a home improvement center call Menard's. I think they are only here in the Midwest, but I'm sure you can find this product or a similar one at Lowe's or Home Depot. It's called Recycled Rubber Roofing made by Specification Chemicals, Inc. The smallest size it came in was 55 ounces and it cost $10.
Let me see if I can find some small containers and maybe I could mail you some for a few bucks and save you some $$$
Old 12-24-2002, 08:56 PM
A temporary fix I did was to switch the drive wheels out with the russian's. The larger wheel makes all the difference. I'm definately going to get that rubber stuff though. It should add grip and make the wheel larger.
Old 12-25-2002, 04:38 AM
epilot epilot is offline
Good question. I am concerned about that too. I have just ordered the winter battle set so it will probably be a while before I wear mine out. However it does concern me that there seems to be no after-market support from Konami. The tanks are expensive enough that people will try to keep them running rather than scrap them when parts wear out.
Remember to keep the tanks away from sunlight - the UV light will harm the rubber over time.
Michael
My New track and a pic of my work area zydio ZipZaps Gallery 15 01-12-2005 04:17 PM
Track idea, comments wanted MoobY Tracks 3 12-07-2004 09:01 PM
Porta-Trax announces SuperCircuits Pro Track Kits lornecherry Bit Char-G / MicroSizers 18 04-02-2004 12:34 PM
Track layout idea Talon Bit Char-G Mods and Projects 0 12-31-2002 02:39 PM
Need help track materials.. NewbieBrigade Bit Char-G / MicroSizers 2 08-06-2002 03:18 PM
