12-18-2002, 09:42 PM
hay u guys whats goi-
Bit Char-G charging light not working...
The charging LED of my 35MHz Skyline GT-R History set isn't working. It'll flicker sometimes, but 99% of the time it won't come on at all.
Any ideas? There are no loose wires or anything in the controller.
12-18-2002, 10:03 PM
Does the car still charge when the light doesn't work?
My Mach 5 has to be on the charger just right.
12-18-2002, 10:10 PM
Yeah, it apparently charges just fine.
12-18-2002, 11:31 PM
Anybody else? Any clue whatsoever?
12-19-2002, 09:56 AM
ive had problems with a few cars where the charging posts in the car come loose and slide back. you gota push em back where the terminal meets the battery. its easy
12-20-2002, 09:10 PM
MyMicrosUnderTheFridge...
It could be a cold solder joint on your LED. Try wiggling it while you are charging, and see if it lights. If it's flakey, open up your controller and re-solder the LED pins.
12-22-2002, 07:13 AM
in fact, BOTH my Skyline history sets don't light up. I got them totally different places too, online, and locally. When i test them, i only get about .5 volts, so i think there is something wrong. I opened them up and found that shorting out two things to get it to work. Its really weird.
01-09-2003, 12:00 AM
BACKINBLACK, DO U STILL NEED THE 49,HZ CASUSE HOBBICO SEND U A 27? I GOT THE SAME PROBLEM, BUT OTHER WAY AROUND! I WILL SELL U A 27MHZ! EMAIL ME!
01-09-2003, 01:20 AM
TinyRC Sith Lord
could be something as simple as putting in some new alkaline batteries.
Mine: red S2000 27mhz
Hers: blue subaru WRX 45mhz
Mods:
2.6 motor
8.25:1 gear axle
medium tires/soft stabilizer bars
l.e.d headlights
rare earth magnet
