Old 12-16-2002, 10:59 PM
kenny_dilger kenny_dilger is offline
PCB Not working (Strange Dual battery symptoms)
I just modified my car to use dual batteries. I did it before when I had a swapped PCB and things stopped working after a while. I am charging the batteries with a peak charger.
Here is the strange stuff... The battery voltage of the pack is at about 2.5 volts. Once I connect the ground wire from the PCB the voltage immediately drops to about 1.5 volts and the PCB get a little warm.
Right now the PCB does not respond to controller input. I read where it could be the ground wire touching the heat sink so I am checking that out, but I don't think that is it.
Any other ideas? What could I be doing to the PCB? The same thing happened to the clone PCB that I had in the ZZ.
Thanks,
Kenny
My ZipZap now runs circles around my Bit! (dual batt success) caver01 ZipZaps 16 11-05-2002 11:22 AM
PCB Mod and Dual Battery Mod are both safe? tylude ZipZaps 5 10-26-2002 04:11 PM
dual battery mod no speed increase? delmonk Bit Char-G Mods and Projects 7 10-17-2002 12:10 AM
ZZ Dual Battery Mod Mattydiah ZipZaps 1 10-14-2002 10:58 AM
