Old 12-13-2002, 05:50 PM
8ate8 8ate8 is offline
Send a message via AIM to 8ate8
nothing but donuts
ok, this is getting annoying. my car does go straight when i'm not turning, but as soon as i turn, the car spins out. i can tap the left or right a bunch of times to turn so it won't spin, but then it takes about a full 2 feet to make a left turn. i want to build a track, but i think it would be pointless if all i'm going to be doing is donuts.
any suggestions?
Old 12-13-2002, 05:58 PM
MicRoMaN's Avatar
MicRoMaN MicRoMaN is offline
Microman to the rescue!!!
Well u can check the steering thing on the bottom of the car, and adjust that. Or it maybe because it has too much power right when it comes of the charger thats why it does donuts. When it takes longer too turn it may be because its running low on life, or is starting to go out of range. Hope that helps!
-----My Mini R/C Site-----
Old 12-13-2002, 06:09 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
rare earth magnets
Old 12-13-2002, 07:12 PM
Pojo's Avatar
Pojo Pojo is offline
Corolla Power!
What tires you got on it, and what kind of surface is it runnin on?
Old 12-14-2002, 12:34 AM
i think you misread. the car goes straight. it's not the steering correction switch. it does donuts the whole time til it dies. and when i mean it takes longer to turn, i'm doing that on purpose. i just tap the left or right and let off of it, and do it repeatedly to turn without doing donuts. that's the only way to prevent it from doing donuts, but then the turns are wider.
rare earth magnets
i don't see why that would make a difference. and i have them. it did donuts all the time when i had the stock magnet, and it still does it with the rare earth magnets.
i've got hard in the back and soft in the front, but it still did it when i had mediums all around. i've run it on linoleum, hardwood floors, slate, table cloths... basically everything, and it's always spinning out when i turn.
Old 12-14-2002, 05:31 AM
usagi20
Try hard front tire with soft rear tires,and a soft stabilizer bar
Donuts - ice skating martdaman Bit Char-G Mods and Projects 9 03-09-2004 09:02 PM
i wish my xmod could do mad donuts like that! skklown XMODS 14 01-16-2004 08:57 PM
donuts? 4G63T XMODS 3 10-31-2003 12:30 AM
350Z Donuts usagi20 Bit Char-G / MicroSizers 23 11-24-2002 04:34 PM
2.6 motor results in donuts galore MattM Bit Char-G Mods and Projects 5 09-02-2002 02:08 AM
