Old 12-11-2002, 09:54 AM
TallgeeseIIII's Avatar
TallgeeseIIII TallgeeseIIII is offline
Send a message via AIM to TallgeeseIIII
TallgeeseIIII's Bit Char-G Ideas & Concepts
Edit 4:
-- Random Edits
Edit 3:
-- Table of Contents Added
Edit 2:
-- Another New Idea Added
Edit 1:
-- New Ideas Added
Allow me to introduce myself, I'm TallgeeseIIII or TG4 for short, call me either, I'm 16, and I'm just getting into Mini RC Cars, especially Bit Char-G Cars. Im Planning on getting the Toyota Supra from http://www.jdmtoys.com. I'm going to paint it shiny green.
Toyota Supra Mods:
- 01. Dual Better Batteries
- 02. Antenna on the Hood
- 03. Head, Tail, and Signal Light Mod with Microswitch
- 04. Stronger Antenna
- 05. Brights
- 06. Dual Muffler
- 07. Let-Off-Gas
Remote/Charger Mods:
- 01. PSONE Controller Shell
- 02. Stronger Antenna
- 03. 9-Pin Controller Adapter
- 04. Let-Off-Gas
I'm getting an 8:25:1 gear set with a 3.8 motor and medium tires.
Here are my Ideas, Theories and Concepts, I've always been somewhat of an ideaman and I hope I can help you guys with some cool new mods.
Table of Contents
- 01. LED with Micro On/Off Switch
- 02. Capacitor Boost Theory
- 03. Sticky Tires
- 04. Magnetic Field Theory
- 05. Roll Cage
- 06. Stylish RC Remote
- 07. Brights
- 08. Police Car
- 09. Panic Button on your Remote
- 10. Turn Signals
- 11. Side Mirrors and Windshield Wipers
- 12. Hovercraft
LED Head and Tail Lights with a Micro On/Off switch next to where the antenna comes out in the back of the car. This has been doen before but it's still cool.
What if you added a capacitor between your battery and charger nodes, so that it charged while you charge your battery, it takes a few seconds longer to charge because some of the power goes to the capacitor first, then when your battery is full, you use it as you normally would, then when you hit the boost button, you have it set up to release the capacitor, adding it's energy to the battery's, giving you added power to the motor without installing a second battery.
3. Sticky Tires
I think Sticky Tires would be great, much less turning ability but it might be helpful for steep inclines, or road rage races where it could lose by flipping.
What if you had a small Electro Magnet controlled by the boost button. When you hit the button, a small mag-field is created that stops all motors within a few inches (including yours most likely).
5. Roll Cage
I thought of this while looking at my fireplace screen, it might be interesting, fun too.
What if you took a Gamecube or PS2 controller and gutted it, then replaced the parts with the inards of your Bit Char-G Remote. Just leave the charge nodes lying limp on the outside, some rewiring might need to be done for the antenna, charge nodes and definetly the control sticks but I'm sure it is possible.
7. Brights
Use mini two-way bulbs for the headlights and a microswitch with ON 1/On 2/Off settings for Bright lights that drain your headlight battery faster but only used for racing in the dark.
8. Police Car
I haven't seen anything about a police car being made which is surprising considering how easy it would be.
Depending on how fast your car is, it may not stop instantly, I don't know what the specific stop distances are for these cars at what speed but a panic button that locks the engine might be needed for an emergency. To tell the truth I don't think this one is really necessary but who knows.
10. Turn Signals
Might be interesting if you're going for realism. Drilling holes and putting mini orange LED's in attached to the steering mechanism (small electro megnets steer the car from what I hear) would be pretty cool.
No real purpose at all but hey, if you're going for realism, why not.
12. Hovercraft
I've heard of this being tried, but I'm sure it's possible, I still have the half wrecked body (tragic snow accident, don't ask) of my old big rc one left to use as blueprints.
My Dream Car (No, I don't have it yet):
Shiny Green Toyota Supra
Old 12-11-2002, 11:11 AM
Crisp_Rapper Crisp_Rapper is offline
Send a message via AIM to Crisp_Rapper
the antenna in the front mod with a metal, not coated wire antenna,
depending on what wire you use, it could put your car off-balance.... which is a bad thing.
Old 12-11-2002, 02:59 PM
yeah, i'm not worried about that, i'm basically using the asame kinda wire on regular rc cars except the same length as my previous antenna
Old 12-11-2002, 06:48 PM
SPEED's Avatar
SPEED SPEED is offline
SPEED IS GOOD
You got some nice ideas there. AS for the Antenna thing, Real RC's use multiple stranded wires on there RX's. These are much like the antenna's found on the Bits. Your better off getting a Solid Copper core wires much like one found in a CAT 5 Cable. As for some of you other ideas such as the panic button, it's really not needed, BITs stop pretty quickly. And for the Side mirrors, the bit bodies already have side mirrors, but not the actualy "mirror" part. Nice idea's keep it up TG4
SPEED-The state of being in rapid motion
Old 12-11-2002, 07:07 PM
thanks speed, you're a nice guy, btw, i'm not getting any double stranded... or whatever you said, i'm getting one that's just solid wire, there's a pic on this forum, in the look here first topic, then click new antenna ideas, then scroll down to the pic, it's almost exactly like that.
Old 12-11-2002, 08:14 PM
carb0's Avatar
carb0 carb0 is offline
accord master
Send a message via AIM to carb0
almost all have been done except for a couple listed
all pics that i post are not mine unless i indicate so, i grab these from extensive web-browsing some more extensive than others, i cannot remember where i got them or who made them so please dont ask nor accuse
Old 12-12-2002, 01:00 PM
datamonster datamonster is offline
I'm with stupid^
Send a message via AIM to datamonster
shouldnt your name be TalgeeseIV instead of TalgeeseIIII? other than that, you have some pretty good ideas. i like the magnetic field theory, but that would be pretty hard to make happen.
Custom Body Kit, Rare Earth Magnet Mod, No Cripple Capacitor, 30 ft. Range
Old 12-12-2002, 09:13 PM
1llusI0n 1llusI0n is offline
BitOnline GM
Send a message via AIM to 1llusI0n
those are some wicked ideas but pretty hard to pull of.
Old 12-13-2002, 02:32 PM
yeah carb0, I know you're right, I have been doing more research and found sites with a lot of these already done. and i'll just add datamonster to the list of people to have told me that for the last 4 years, and that totals, 473, so many people tell me that, but my way is never taken on forums and stuff, i think of them as tallies instead of roman numerals. oh, and thanks 1llusI0n!
bit char g!!!!! sengming Bit Char-G / MicroSizers 3 01-20-2003 03:36 PM
tallest bit char body? Sniper596 Bit Char-G / MicroSizers 2 11-23-2002 08:16 PM
bit char g - bit char g bike -bullet 00gt Bit Char-G / MicroSizers 1 10-26-2002 03:30 PM
Bit Char G Help superbee Bit Char-G / MicroSizers 3 10-03-2002 04:51 AM
