Old 08-02-2002, 11:22 PM
nivirt nivirt is offline
My RX7 Drop Top Modded Bullet
Just finished up the body work on my Rx7. What do you guys and gals think?
Still have to finish the interior with a driver ( just found one of those cut guys from the elbow down ), it's more scale like than the Rally Stock Styles.
Old 08-02-2002, 11:44 PM
kbtoyz902's Avatar
kbtoyz902 kbtoyz902 is offline
Bit OG
Send a message via AIM to kbtoyz902
nice, i like it. Is that an RX-7, looks much more like an RX-8 to me. but nonetheless, it looks good, and you did a nice job
Old 08-03-2002, 01:26 AM
tinyrc's Avatar
tinyrc tinyrc is offline
nivirt, it looks awesome! Where did that body come from though?!
Old 08-03-2002, 07:50 AM
TinyRC, I guess a picture is worth a thousand words so, here's a side by side comparision of a stock "Mini Mover" OEM Bullet to the mod.
The body was first lowered by .050". rough cut the top off with a Dremell cutoff wheel and trimed up with an Excto. The back was then formed with a piece of window film taped on and then glassed from the inside.
The front brake holes and side air exit holes were cut out.
The electronics cover was removed because I'm getting ready to add an interior shelf for the driver and the board was taped on with a piece of 1/16" fine line tape.
It was filled in and primered, a white base coat was sprayed and then the yellow pearl added and then the whole thing was clear coated. The picture doesn't do the color justice
Old 08-03-2002, 09:11 AM
tinyrc's Avatar
Wow! After seeing the low detail body that it started out as, I'm even more impressed! Amazing job!
Old 08-05-2002, 09:36 PM
Zagatto
Those are some nice clean cuts... I gotta get a dremel.
Were you planning on doing anything to the back for detail? Either a roll bar or a faux cover for the "roof".
Old 08-09-2002, 12:38 AM
Alex's Avatar
Alex Alex is offline
sex: Yes please!
Send a message via AIM to Alex
make it like a supra that it has the detachable sunroof and make a detachable sunroof!!! that would be AW-SAM. 2 in 1 Rx7
Old 08-09-2002, 12:58 PM
I'm waiting for some driver figures now, these are used in HO slot cars. I plan on doing a deck with instrument cluster and driver and possibly a roll bar. I also order a bunch of HO lexan bodies than I plan to remake to fit these cars. I'm a little partial to the "60s and '70s LeMans style cars so I'll have to see what tickles my fancey when they arrive. Also, I ordered some HO rims that are duplicates of some of the mags of that era and some 5/8" diameter tires, I know I"ll have to make some adapters for the axles size difference but, that won't be a problem.
Old 08-09-2002, 01:46 PM
tinyrc's Avatar
Cool, keep us posted on your projects; would you like an Album in the Gallery to showcase your creations?
http://tinyrc.com/galleries/
Old 08-14-2002, 04:32 PM
tinyrc's Avatar
Nice job Gigabite!
Old 10-24-2002, 11:18 PM
NorCalCoug's Avatar
NorCalCoug NorCalCoug is offline
l33t camber wizard :)
Holy CRAP!!!!
That thing rocks man. I need to outsource the bodywork for my race cars to you..
Old 10-24-2002, 11:26 PM
323iT's Avatar
323iT 323iT is offline
Send a message via AIM to 323iT
Thumbs up
very nice!!! keep up the good work!
Old 10-25-2002, 10:17 AM
DriveWRX's Avatar
DriveWRX DriveWRX is offline
Excellent job! Very clean! I like very much!
Nice color too...
What method did you use to lower the body?
What do you mean by "glassed"?
drop top VW sm2osley Bit Char-G / MicroSizers 15 07-29-2003 09:04 PM
Silver bullet RX7 sessiz10 Bit Char-G Gallery 5 03-21-2003 02:19 AM
