Old 12-10-2002, 12:36 PM
motobandit motobandit is offline
Battery Charging?
I've read in a couple different posts about people charging their cars two or three times between uses. Does this help performance? If so, does it make the car faster...or does it make it run for a longer period of time? Also, does it cause any damage to the battery?
Underpromise; overdeliver
Xanavi Hiroto, 2.6, 57mhz
Telescopic antenna
ZipZap, Silver Porsche, 27mhz
Old 12-10-2002, 01:06 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
well a battery gives off peak voltage when fully charged and gradually drops as it drains so yes you get a slight perfomance increase and the battery lasts longer between charges. as far as i can tell its not ruining the batteries. if it does they are cheap.
Old 12-10-2002, 01:10 PM
Do you know how many times they should be charged...2?...3?...more?
Telescopic antenna
Old 12-10-2002, 01:18 PM
ripper7777777 ripper7777777 is offline
I charge 4 times, and havn't had any problems yet.
Old 12-10-2002, 01:24 PM
What kind of run times do you get with 4 charges?
Telescopic antenna
Old 12-10-2002, 01:27 PM
payaso payaso is offline
BIT PIMP
20 + minutes easy.... Don't charge more than 4 x just to be safe.
silla
Old 12-10-2002, 01:29 PM
Thanks guys, sooooo helpful!
Telescopic antenna
hogjowlz's Avatar
once a battery is full it starts to get hot which could damage the battery. 2 charges gives 5mins of peak performance easily. if i triple charge i get bored before the battery dies.
Old 12-11-2002, 10:06 PM
Spy021 Spy021 is offline
Just got my microsizer today and had a quick question about charging it.
When I but in on the remote to charge should I be lightly pushing down on it while it charges? The reason I ask is because it seems that if I just snap it on the charger, the charger LED lights up, but is a bit faint. If I apply a bit of pressure or wiggle it around, the charger LED sometimes lights up very prominently. I seem to not be able to get more than 2-3 minutes out of a charge, even if I try to charge it, remove it and then immediately charge it agian.
If anyone has any advice, I'd appreicate it. Oh yea, by the way, the car is completely stock at the moment.
Build a Stand-Alone AC (or battery) charger SuperFly Tips, Mods and Reviews 0 09-03-2003 07:22 PM
FYI:Motor Works (clone) charging base will charge dual and triple battery setups. Clint Bit Char-G / MicroSizers 0 02-17-2003 04:09 PM
More powerful steering for 2-cell mod? bonus: faster charging for dual battery mod Chris Bit Char-G Mods and Projects 1 11-23-2002 07:24 PM
