Old 08-02-2002, 06:53 PM
fupia
Unhappy Ratio Gears That Don't Fit...help
Hi, I bought a set of those ratio gear thingies (s-01) and I tried putting it on my Trueno. It doesn't fit and I'm wondering...why...someone help? Thanks.
Old 08-02-2002, 07:36 PM
ylexot ylexot is offline
Well, I hate to tell you this, but the gears don't work because they are for the Bit Racer cars, not the Bit Char-G cars. They can be modified to work, but A) they won't work very well and B) I don't know how to modify them because I've never tried it. I believe the proper gear set is GS-03.
Xanavi Hiroto Skyline GT-R 57MHz
Booster 35MHz
MicroQ Porsche 45MHz
Peugot Bullet 49MHz
Skyline GT-R Bullet 40 MHz
WRC Impreza Nikko iRacer
Subaru Impreza and Toyota Bb Bodies
Old 08-03-2002, 07:21 AM
sharpshooter sharpshooter is offline
Send a message via ICQ to sharpshooter
you can modify it by filing down the spacer towards the inside of the right rim, you will know when your done if it snaps in place.
I just tried it today and I was told to use the white pinion gear with it, but in the end, not all the gears mashed properly.
but I wouldn't recommened it anyway.
shoot to kill
Old 08-03-2002, 11:25 AM
fupia
Yeah, I tried it and the gears didn't fit. So I'm just using the white gear parts.
Old 08-05-2002, 10:20 AM
carver carver is offline
mine worked ok.only problem was it had too little acceleration.wasnt really worth my while.i used the red gear by the way.maybe u sanded the spacer a bit too much thats why it got too loose.
Gear ratio for a long hard pull frizzen ZipZaps Mods and Projects 15 09-09-2006 04:00 AM
Do ZipZap gears and motors fit Bits? mde Bit Char-G / MicroSizers 2 01-18-2004 07:52 PM
The maximum gear ratio..... charliebrown ZipZaps 9 01-13-2004 03:55 PM
Pinon gears. dje7447 Bit Char-G / MicroSizers 7 10-09-2003 03:52 PM
clone gears vs bit gears ? Mike the Great Bit Char-G Parts and Hop-Ups 10 01-19-2003 01:05 AM
