Old 12-08-2002, 09:53 PM
AxcZZ AxcZZ is offline
how do you lower your ZZ?
when i first came to this forum i read through almost all of the threads. i read one where you can make the car look lowered. is that possible?
Old 12-08-2002, 10:10 PM
Stridex's Avatar
Stridex Stridex is offline
Chunk
The only quick fix for lowering that I've heard is to putty up the old holes and make newer ones higher up. I think you'd run into a problem with steering and possibly have the backwheels touch if you don't feel like dremeling. You do have a couple other options, but in order to do it right and make it look SWEEET it will take time and patience. You can add to an existing body using plastic strips and epoxy putty, or you can go and buy a lexan body (most likely one for an HO slot car) that still has the wheel wells still filled in. This way you can cut them to size. Most hobby shops should have these. The larger hobby shops that is. Ma and Pa's normally only carry the larger scale stuff. http://www.radtrax.com sells them online, but I just looked and they're all out of stock and no pictures to show.
A religious war is like
children fighting over
who has the strongest
imaginary friend.
Old 12-08-2002, 10:36 PM
thanks for the tip stridex
well, is there any other ways that you can lower your car without making anything worse?
Old 12-08-2002, 10:41 PM
Stridex's Avatar
Chunk
I wish there was. You could try making a ground effect kit and glue it on. That would be fun, but everything related to lowering bodies is tedious. If you have two bodies of the same style, you could knife off the lower part of the second one and glue it on the first. That would be quick and painless. You'd probably have to paint the ground effect kit you just created to hide the knife marks. Maybe even a little bit of sanding.
imaginary friend.
Old 12-08-2002, 10:57 PM
alright, thanks
Old 12-09-2002, 06:40 AM
hiero's Avatar
hiero hiero is offline
^STREET RACER 209
Dude when is that pimple gonna go away?You are in bad need of a dermotology department.hehe lol.
I think your underestimating my snekieness sir.(quote from Mr.Deeds)
Old 12-09-2002, 11:04 AM
Stridex's Avatar
Chunk
Sneaky, sneaky, sir!
My avatar is a tribute to the best Moderator(stride) ever over on the other board. It's my little shrine to show him how much we appreciate his childish antics and his female facial features.
It's either the pimple or him tucking his twig and berries between his legs. You decide which one you want.
imaginary friend.
Old 12-09-2002, 02:10 PM
go_zz_go's Avatar
go_zz_go go_zz_go is offline
more power!!
hey stridex over there they have a zz only board which means no pimple face to bug you hes only in the bit side just to let you know
Old 12-09-2002, 02:16 PM
Stridex's Avatar
Chunk
That andrea girl bothers me even more. She just never put up any pics.
imaginary friend.
Old 12-09-2002, 09:34 PM
BigPimpin BigPimpin is offline
Fugative
dude i painted grond effects on my car...
its hard to lower the body, it doesnt work on some cars, the tire rubs.
Old 12-10-2002, 01:17 AM
hiero's Avatar
^STREET RACER 209
well if its between the pimple and the barries i choose ummm....lol the pimple its just that the thing has been poped like 450,000.0000 times you would think by now it would be gone.
Old 12-10-2002, 01:58 PM
MICROMAZDA MICROMAZDA is offline
Send a message via Yahoo to MICROMAZDA
You can lower you ZZ. I lowered my PT but it does scrub sometimes. But it looks sweet!
My intention was to get my dremel out and place a slot above the already stock one, but I was lazy and did it with an Xacto insted. I broke through into the stock one and now the hole is bigger than I wanted it but it lowered the car pretty good.
Either I'l leave it just to show or I'll sand, putty fix and repaint. It has a wing on the top back too. Like a ricer car. And BLING BLING! Gold spoke rims
Old 12-10-2002, 02:50 PM
go_zz_go's Avatar
more power!!
slamming em is easy it was the first mod i did,,,,yeah the tires rub but thats why you round out the fender wells..its easy and is a must to get a zz looking good check out the thread easy mod 1
Lower Rizzle Bit Char-G Mods and Projects 2 11-27-2004 05:49 PM
hey can any 1 tell me how to lower my zz pleeese racemini89 ZipZaps 1 07-02-2003 05:31 PM
New idea to lower your car! xatu Bit Char-G Mods and Projects 4 03-22-2003 09:05 PM
lower your car with glue and sandpaper Chronic Bit Char-G Mods and Projects 13 11-08-2002 10:48 AM
