Old 07-31-2002, 06:37 PM
schoon's Avatar
schoon schoon is offline
Send a message via AIM to schoon
Question Lowering Rear Suspension
OK, between dual springs and other front end mods, I think that lowering the front of your Bit is pretty well covered.
However, the rear is still sitting pretty high, and the chassis shouldn't be canted too far if you expect it to corner well.
So here's my challenge: how do you lower the rear and/or provide dampening for it?
One potential fix would be the small-rear-wheel mod, but there must be more!
Old 08-17-2002, 03:49 AM
QFM Racing's Avatar
QFM Racing QFM Racing is offline
Moderator - Modifier
separate the rear motor well from the main chassis, leaving only the motor wires connected to the motor. Use a flat narrow copper strip of metal, and reconnect the motor well/axle to the chassis, via the strip. Simply bend the strip to adjust height. The strips tension, depending on how far you choose to have the motor well/axle extend out, will provide the suspension you need.
Hope you can visualize this... Its one of our future mods, but not on the priority list.
www.questformadness.com
(the Bit Modifeds how-to page)
QFM Racing's Custom Bit Modifieds (The Bit How-To Page)
http://questformadness.com
Front suspension in rear T Man XMODS Mods and Projects 14 06-27-2005 06:35 PM
Rear suspension upgrade idea... neurokinetik XMODS Mods and Projects 2 12-29-2003 03:24 PM
Misaligned left rear suspension arm neurokinetik XMODS 1 12-05-2003 10:39 PM
Tuning Basics sperry XMODS Parts and Hop-Ups 12 11-19-2003 01:56 AM
Rear suspension on a bit? chelboed Bit Char-G Mods and Projects 28 04-13-2003 10:51 AM
