Old 12-06-2002, 12:07 AM
metawu's Avatar
metawu metawu is offline
Light wiring
I have 4 LEDs and two 3V cells (and a switch)
When I wired it up (in different ways, with both one or two batteries, etc) either the headlights or the tail lights could go on. not both.
Once i got both to go on but then the headlamps would get dimmer until theyre completely off.
Anybody know how the proper circuit goes?
Old 12-06-2002, 01:24 AM
alpha1's Avatar
alpha1 alpha1 is offline
Runs with sharp stuff
Are you trying to have them all on at the same time or just the headlights on when going forwards, and the brake lights on in reverse?
Old 12-06-2002, 08:11 AM
metawu's Avatar
all at the same time
Old 12-06-2002, 10:31 AM
hbarer's Avatar
hbarer hbarer is offline
mogi's godfather
lights
you had the
polarities
(+ and -)
reversed when
only one pair would light
as for the dimming
some leds require more than 3v
especially blue and white
try another battery
or just use headlights
i use yellow and red and
thats usually ok
good luck
oink
Old 12-06-2002, 11:33 AM
metawu's Avatar
i guess its the battery, thanks for the help
Old 12-06-2002, 04:27 PM
metawu's Avatar
Well, they didn't really fit in my car, but I basically made 2 circuits (one for the head and one for the tail lights).
Old 12-06-2002, 09:16 PM
ihavebadgas
try putting putty under the light to block the light from escaping through the bottom
Old 12-06-2002, 09:17 PM
ihavebadgas
for if the light escapes then it shall mean certain doom for all of us
ihavebadgas
HAHAHAHAHAHA im insane in the membrane! i love sugar ever so much
Old 12-07-2002, 04:09 AM
alpha1's Avatar
Just wire all the LED's in parallel. In other words + to +, - to -.
Old 12-07-2002, 04:16 AM
delaroca's Avatar
delaroca delaroca is offline
That celica with light mod looks very cool. What components do u need, i'd love to make my celica look like that!
Old 12-07-2002, 04:48 AM
delaroca's Avatar
If the lights are mounted behind the headlight (i.e not cut through the bodyshell) do you have to remove any paint from the inside of the BIT or does it woek fine without??
Old 12-07-2002, 05:44 AM
alpha1's Avatar
You should remove the paint first. On some of the light kits that are available for sale, it comes with some paint remover and q-tips so that you can take the paint off. Most of the newer Bit bodies have the paint on the underside of the body. It's a different story when the paint is on the outside.
I'm out like the fat kid in dodgeball.
Old 12-07-2002, 10:18 AM
metawu's Avatar
I think I tried it parallel and that's when my headlamps dimmed out.
Old 12-11-2002, 09:12 AM
mjb mjb is offline
It will: The red LEDs will suck the voltage down to their level, leaving a low voltage for the whites. Stick a series resistor on the pair of red LEDs (maybe you get away with one resistor for 2 LEDS, maybe you'll need 1 each) and then try again
You may have to cut-and-try the values to get it to work correctly and not suck the voltage down, while still retaining brightness.
Mike
Add light set to your non ZZSE bodies! 'Vette Nerd ZipZaps 1 08-29-2006 04:18 PM
need some info about light kits bengali548 XMODS Mods and Projects 3 08-02-2006 11:44 PM
How to Splice LED's for the Light Kits Bad Company XMODS Mods and Projects 32 06-30-2006 05:13 AM
how to light up your xmods interior without buying a kit rpm XMODS Mods and Projects 2 12-27-2003 08:44 PM
Help with head/tail light installation BCGMan Bit Char-G Mods and Projects 10 01-04-2003 06:39 PM
