Old 12-06-2002, 01:05 AM
broncoman74
Thumbs up #3 Pivot Point Susp. Arm and Soft block tread tires on Toyota Supra Booster Set!
I finally got my Tire Set and my Tuneup Set today. I can't believe what a difference in handling between stock and the #3 Pivot Point Susp. Arm and the Soft block tread tires makes. My Toyota Supra Booster car does not flip over as easy and the cornering is fantastic. Instead of doing donuts everytime I turn the wheels it gives a little so you can plan your turns better in tight spots. Now all I need to get is the Gearing Set and a 3.4 Darkside Rotor or a 3.8 Motor(I still have not decided yet).
