Old 12-03-2002, 09:56 PM
karlos karlos is offline
Send a message via AIM to karlos
Talking 3.5 BitMOd1 motor is the $%&*
SO my 3.5 BitMod1 motor came in today along with a booster set for testing. I am running a 150 mah battery and 12:1 gears. I raced my wife with my auto modellista r34 skyline with the 3.5 motor against her and my r32 with the same setup but using the 3.8 (bought here ofcourse ) and it was not contest ! Not only did I walkaway on the hardwood floor my r34 with the 3.5 ran onto the carpet (and its not low pile ) and kept going .. whew I just had to say it since I didn't see many comments on this one. Who thought .3 rpms would make a diff
Old 12-03-2002, 10:13 PM
SmokenRubber SmokenRubber is offline
Send a message via AIM to SmokenRubber
very intersting now how does one do such a mod?
I will Smoke u.
Old 12-04-2002, 11:58 AM
Its a motor sold through bit1mod. Its their 3.5 motor.
Old 12-04-2002, 10:37 PM
Snow Snow is offline
DDR PIMP
Not to be nitpicky and correct you, but it's actually a 5,000 rpm difference.
Thunder Charger
Old 12-05-2002, 12:21 AM
Acceptable_Risk Acceptable_Risk is offline
Not to be nitpicky to you but there's a 3000 rpm difference.
Old 12-05-2002, 04:26 AM
sketch sketch is offline
Send a message via AIM to sketch
yeah my 3.5 motor came in yesterday (i actually bought 2)... and i'm lovin it! I used one on my Trueno, and another on my Wild Char-G! Highly recommended! it works nicely on my wild char-g!
Old 12-05-2002, 07:41 AM
Actually Snow is right if your using the boost button. There is a 3,000 rpm difference but when you hit the boost button I believe it kicks in another 2,000 rpm.
Old 12-05-2002, 08:14 AM
DDR PIMP
lol, yeah that's what I meant. Or that's what I would've meant if I knew how to add. I wasn't saying that just to feel cool or informative, just point out that 3,000 rpm would make a bigger difference than .3 rpm.
Thunder Charger
Old 12-05-2002, 12:23 PM
D'OH ! didn't realize I wrote .3 ??
Old 12-05-2002, 06:04 PM
Whats the difference between 1.0 2.2 2.6 3.0 and 3.8?
which one would make the car go super fast but not kill the left right motion?
I will Smoke u.
Old 12-05-2002, 06:35 PM
With a 3.8 you will more than likely flip over when you try to turn so you'll have to slow down some. With the 3.0 you shouldn't be flipping as much on turns if your flippin at all. The 3.5 I noticed I don't flip over nowhere near as much as with the 3.8. Thats why I use the 3.8 in my "drag" car
Old 12-06-2002, 08:20 PM
TemjinNeo78's Avatar
Bit Drag Racer
in my experience the fastest motor with a bit racer gear(3:43) is atcually the 3.8 you can punch out 11079 rpm (110,790 scale speed) Thats the speed of about 2 3.8's . Now maybe since u say these babies are faster than a 3.8.......tie for me to open up my wallet. BTW did your motor come with a white pinion gear also?
Old 12-07-2002, 07:09 AM
The 3.5 didn't come with a white racer gear..hmm I am going to have look into this 3:43 gear
Old 12-07-2002, 08:08 PM
mattgoldey's Avatar
mattgoldey mattgoldey is offline
I have the 3.8, with my tire/suspension setup I still occasionally flip over and my turning radius is pretty wide while I'm on the throttle.
I have heard that the 3.2 & 3.5 motors from bitmod1.com are better than the 3.8 because they have lots of torque which means they're quick off the line & can run on carpet.
Bit Char-G Toyota Celica (silver)
* Custom Mica Blue paint job (just like my real car)
* Rare Earth Magnet steering (Radio Shack Cat. No. 64-1895)
/]My 2000 Toyota Celica GT-S[/url]
Old 12-10-2002, 08:53 PM
skylineracer skylineracer is offline
what is your setup?
do you mind if i ask you what your setup is? i have a 2.6 with 8.25:1 gearing and anything i try just doesn't seem to help with steering and handling. thanks.
bitmod1 3.5 Critter Hart Bit Char-G / MicroSizers 12 12-29-2002 11:38 AM
bitmod1 3.5 vs. 3.8 results aero Bit Char-G / MicroSizers 7 12-16-2002 11:06 PM
Bitmod1 3.2 and 3.5 motors... VERTiG0 Bit Char-G / MicroSizers 5 12-06-2002 11:51 PM
bitmod1 3.5 motor - good?bad? aero Bit Char-G Mods and Projects 0 12-03-2002 10:40 PM
