12-02-2002, 08:55 PM
What It Is To Burn!
DIGI Q...........whats so special??
They are expensive!!! What scale are they?? Whats so special bout em?? They look cool as hell though.........
So Tell Me, What's The Price To Pay For Glory?
Bit Char-G Fairlady Z 57Mhz (2-Speed), 3.5 or 3.8, 150mAh NiMH, Blue Gears
MicroSizer RX7 27Mhz (Originally a 27Mhz Celica) (Injured Reserve)
ZipZap Supra (Originally a 49Mhz 911), DKS 2.8, 150 mAh NiMH, Red Gears
12-02-2002, 09:09 PM
Life's a... Bits
I think would be better for you if you ask that at the DigiQ Forum.
Nissan Gloria 2.6 + LightMod + 120mAH Cell -- Honda S2000 Silver 3.0 -- Nissan Fairlady Z 3.0 -- Toyota Supra Silver 3.0 -- Mach 5 3.8 -- Ultra Patrol 3.0 -- Ultra Cosmo 2.2 -- Auto Modellista 2.2 -- Bir Racer TRAX Green 2.6 -- DigiQ Subaru Impreza -- Ferrari Set -- LXX -- AudiTT SE ZipZaps -- Mazda RX-8 XMen ZipZaps
12-02-2002, 09:19 PM
They're real quick and they're oh so tiny.
12-02-2002, 11:27 PM
What It Is To Burn!
are they smaller than bits?
12-02-2002, 11:34 PM
A little.
12-02-2002, 11:37 PM
What It Is To Burn!
i was just looking at them, they look sweet!!!! any bit head have one??? toy east has them for $34.00 which seems cheaper than most........plus they use 2 engines!!??!!
12-03-2002, 12:11 AM
The wheels in the front don't move. The rear wheels are independantly driven, hence two motors. They also use proportional control. They're controlled by IR, which can be both good and bad. About the only downside is they're not quite as customizable.
12-03-2002, 12:13 AM
What It Is To Burn!
i noticed that and that does suck...............imagine stuck with the same old motor forever................are they fast enough that i won't need to upgrade the motor though?
12-03-2002, 03:05 AM
dont worry about digiq are twice as fast as a bit
12-03-2002, 05:30 AM
Runs with sharp stuff
They are pretty fast, but it takes like 4 minutes to charge for some reason.
12-03-2002, 09:37 AM
Bit Gothic
and is has a different steering system than bit's, it moves like a "tank" when you want to turn right, the tires on the right side goes slower ... i prefer bit's steering system !!
12-03-2002, 09:48 AM
They are so fast that you would never want to upgrade! Even at half speed they are rediculously fast. Don't forget, however, that they are proportional, which helps control all of that speed!
http://www.tinyrc.com/shop/products.php?pid=9
12-03-2002, 09:58 AM
You can get a Nikko IR racer at Toys R US for $30.00. It's the same thing but its actually labled as the worlds smallest car at 4.55cm and a Digi q is 5cm. Toys R Us has a mini cooper and a benz and they are much faster out the box than a bit, but the bit can be customized to be faster.
12-03-2002, 09:59 AM
What It Is To Burn!
Well thank you everybody for your help, I think I am going to get one. I want the controller with the led and the car with the lights!!!
