12-01-2002, 10:44 PM
DigiQ Wizzard
Propo Special controller codes
Hey does anyone know where I can find more codes to program my Digi-Q Propo Special controller with??? I found 15 of them at Sigmaautomotive.com. If anyone has any codes please share them and I will also list new codes when I find them. Thanks!! www.sigmaautomotive.com/TechieMon/digiqps.html#codes
12-02-2002, 07:02 AM
Hi,
I have the Special Controler, but I don't have any idea on how insert the reportd code .
Any tips on how to use them ?
e_lm_70
12-02-2002, 11:17 AM
DigiQ Wizzard
How to enter the codes
OK, To enter the codes you hold down select until speed starts to flash on the LCD screen on your controller. Then you press select (dont hold it down) and cycle through the choices until you have the word "code"showing. Now beside the word "code" is 4 numbers, bny pressing select it should make each number flash, just like setting a digital watch, all you have to do now is use the up and down bottons,to set each number and press select to go to the next number. When you are finnished you hold down select until everything stops flashing. I am not very good with instructions so if you need more info please give me details of what you want to know exactly and I will answer the best I can.
12-03-2002, 01:20 AM
Thanks
I will try this evening ...
e_lm_70
P.S: My Digi-Q TT is taking mainly a lot of dust now !
12-03-2002, 03:11 AM
DigiQ Wizzard
Let me know if you have any questions. As for everyone else who reads this- FIND MORE CODES!  I have tried all 15 that I got from Sigma and I found some of them to be very useful, so if anyone knows anything or can find more codes it would be great! I have been searching day and night using Google and I have ran out of options.
12-03-2002, 11:50 AM
Konami codes
Code Description
9727 - 9757 Puts the car into spin when the trottle is pressed all the way.
9153 - 9453 Car is wavering and spins when the trottle is pressed all the way.
9325 - 9328 Tank mode.
0648 - 0678 Mode A without reverse
0184 - 0484 Mode B without reverse
0444 Trick mode. If you can master this mode - you're DigiQ master
0321 Mode A (advanced mode) floor
0322 Mode A (advanced mode) carpet
0271 Mode B (intermidiate mode) floor
0281 Mode B (intermidiate mode) carpet
0343 Mode C (beginner mode) floor
0443 Mode C (beginner mode) carpet
0573 Original DigiPropo EASY mode
9573 Original DigiPropo NORMAL mode
9853 - 9856 Steering and forward/backward reverse
0216 - 0276 Weaving code
0217 - 0277 same
0218 - 0278 same
9147 - 9177 Moves front wheels side to side by vibration
9214 - 9217 Moves front and back by vibration
0761 - 0764 Forward/backward reverse
0423 - 0426 Steering reverse
0512 - 0515 Fixed (non-proportional) speed/steering mode
0555 Parallel parking mode
0556 Parallel parking mode with reversed steering
Sigma Automotive codes
Code Description
2567 Special code for technical courses
3431 Drifting code
5237 Nissan Skyline GT-R code
0818 Spnning mode
12-03-2002, 12:28 PM
DigiQ Wizzard
Sherlock Holmes style!
Good detective work! This is more codes than I even knew were out yet! Great work, Thanks for sharing with us!
12-25-2002, 06:07 PM
what exactly is the purpose of these codes like for example the one for the skyline gtr? If i have a gtr will it make it super fast?? SOrry i'm a newbie.
12-26-2002, 12:55 AM
Sorry I don't know what exactly the Skyline GTR code does but all the codes alter the handleing of the car in some way. They are basiclly "easter eggs" that make your Digi Q do someting "special". An example is Tank mode makes your Digi Q move (act) like a tank.
-Engineering Manager
12-26-2002, 08:14 AM
thanx for the info because i bought the special propo controller and the trueno r so i was just curious about these codes.
12-26-2002, 02:17 PM
Ok forget the bit char-gs i have those are beside the point I NEED A DIGIQ!!!!!
