Old 11-30-2002, 07:43 PM
Denn182311 Denn182311 is offline
do Bit-charge motors work in zzs
Would a Bit- Charge 3.8 motor work in my zz?
Old 12-01-2002, 04:55 PM
ZipRC's Avatar
ZipRC ZipRC is offline
Modder-Eater
Nope
Without some sort of modding, it probably won't unless the PCB gods have blessed u lol. Hope that helps
Old 12-02-2002, 09:42 PM
TemjinNeo78's Avatar
Bit Drag Racer
In order for the 3.8 to work, you would have to jumper the resistors on your pcb(soldering iron needed) so the motor power can bypass the pcb. The resistors currently hold back on the power from the motors, so that is why there are so many ocmplaints about them being slow. You will be able to be use all motors 2.6-3.8 once this mod is preformed.
Old 12-03-2002, 11:11 PM
I2ed I2ed is offline
Send a message via AIM to I2ed
how bout a 3.2 a 3.0 and a 3.5 or was it 3.6 motor? would they fit in a zz?
Blue Honda ZZ w/ Dual Batt Mod
Old 12-04-2002, 01:42 PM
Bit Drag Racer
all of those motors will work as long as you preform te mod.
Old 12-04-2002, 06:20 PM
Thanks
motors (bit charge-zz-etc.) stratocaster300 Bit Char-G / MicroSizers 7 06-26-2004 06:14 AM
Xmod servos use Bit motors!!! viperdout XMODS 8 05-02-2004 08:43 PM
Whats the difference between bit char motors and microsizer motors? ernie Bit Char-G Parts and Hop-Ups 1 09-13-2002 09:50 AM
A New Way To Charge Single And/or Dual Battery Bit Char-g!!~! BaY oN AiM Bit Char-G Mods and Projects 7 09-12-2002 06:19 PM
