Go Back   TinyRC.com > 1/24 and Smaller > ABC DTM > ABC DTM SP
Old 04-27-2002, 11:25 AM
bilbo bilbo is offline
Steering Control
In the June issue of RCCA one of the positive comments about the DTM SP was that of the 5 micro cars tested, it has the quickest acceleration off the line. The only negative comment was that there was no ability to dial out steering. Without this ability, controling the car in corners is difficult. 1) Does anyone know what they mean by dialing out steering?
2) What aspect or part of the DTM SP causes this problem? 3) How could the problem be corrected?
Old 04-27-2002, 03:25 PM
Mykroe Mykroe is offline
Send a message via ICQ to Mykroe Send a message via AIM to Mykroe
1) By dialing out steering that means that you "turn down" the steering or limit the travel. The function is called ATV (adjustable travel volume) or EPA (endpoint adjustment)
2) dunno
3) dont know
<--Mykroe-->
Old 04-27-2002, 04:25 PM
PorscheGuy964's Avatar
PorscheGuy964 PorscheGuy964 is offline
M-Chassis Innovator
Send a message via AIM to PorscheGuy964 Send a message via Yahoo to PorscheGuy964
If you haev a mini-z then you would know that you control this right under the steering wheel....
Old 04-27-2002, 09:10 PM
I was also thinking that adjusting the steering rate with the transmitter would help solve the problem. Or getting a smoother
steering servo might help.
Old 04-29-2002, 09:41 PM
DAMZer's Avatar
DAMZer DAMZer is offline
Bilbo,
You got it right!!
Yes you can dial out steering with most radios. The adjustable thumb wheel changes the max throw on most basic radios.
You can also change the pivot point on the servo arm to reduce or increase the proportion of steering throw in relation to the amount of transmitter input.
Speed & Steering Control hschnark Bit Char-G / MicroSizers 2 03-09-2006 06:39 PM
Ideas on how to increase steering power mde Bit Char-G / MicroSizers 4 05-01-2004 03:42 PM
WOW, another steering discovery! Upgraded steering motor! cyborgzero ZipZaps SE 2 02-22-2004 01:16 PM
