Go Back   TinyRC.com > 1/64 and Smaller > Digi Q > Digi Q
Old 11-25-2002, 10:40 PM
foofinator's Avatar
foofinator foofinator is offline
Can I use one control for all of them?
Say I wanted to buy a set, then buy the skyline GTR body, would I be able to switch IR channels on the stock control or would I still have to buy a new controller? Thanks in advance.
Mah Bits
Loctite Zexel Skyline
Nissan 350Z
Black Toyota Bb
Yellow Toyota Bb
Old 11-26-2002, 01:38 AM
NorCalCoug's Avatar
NorCalCoug NorCalCoug is offline
l33t camber wizard :)
The controller has 4 selectable channels, leaving it easy for you to not have to purchase more controllers.
Old 11-26-2002, 01:41 AM
Adam's Avatar
Adam Adam is offline
DigiQ Wizzard
Different cars with same controler
You can use a standard digi-q controller for any digi-q car. It has the switch on the side to change IDs. But I recommend that you get the Propo Special controler. Also you REALLY need to check out the Combat Digi-q tanks!
How To Build a Micro Speed Control From a Servo Overlander TTTT 20 05-26-2004 01:21 AM
RE: Remote Control Batteries HUN25 Bit Char-G / MicroSizers 0 01-15-2003 03:06 AM
Radio Control Control Vincent Flagg Bit Char-G / MicroSizers 1 12-12-2002 12:09 PM
speed control? go_zz_go ZipZaps 12 11-26-2002 08:13 PM
The bit's worst nightmare...a fall d00kie Bit Char-G / MicroSizers 3 10-12-2002 01:50 PM
