Go Back   TinyRC.com > Customer Support > bitchar-gmotors Customer Support
Old 11-25-2002, 06:56 AM
e_lm_70 e_lm_70 is offline
3.2 Motor
Hi,
Just got my 3.2 Motor from TinyRC.
The motor is not absolutly 100% compatible with my BitCharG, it required some little extra brute force to put inside since the dimension is not same as Bit motor.
The 3.2 is faster the the 3.0Bit and look more torquie then 3.0.
But it is not reliable at all, the internal rotar can easly moving inside and time to time it tend to get bloked.
When the motor get bloked the only way to release it is to shake it a little and manually rotate the pineon till if get free again. Then a nice free run with the top-down car helps.
BTW in overall the speed advantage doesn't pay for the reliability problems, that can happen everytime while the car is running !
e_lm_70
Old 11-25-2002, 07:40 PM
d00kie's Avatar
d00kie d00kie is offline
It's super useless!
Hmm...have you tried pushing the motor gear a little more in? Thats what I did with mine because it wasnt really making good contact with the medium orange gears.
It is a little bigger, thus requiring additional careful force to shove it in.
Old 11-26-2002, 04:27 AM
Hi d00kie
The contact with the gear is perfect (I use the medium (orange)).
I guess that there is some dirt inside the engine. When this dirt go in a wrong place it block the axe of the motor.
Who know if and how is possible to open these little engine ?
Old 12-03-2002, 03:10 AM
Luckily after usage the 3.2 TinyRC has started to work fine.
It has more torque then a Bitracer 3.0 and almost the same top.
The only drawback now it is that it is far more noisy then every bit motor (clone excluded, the good thing of original Bit is that they are pretty silent with a nice non desturbing good sound)
A part from the noise I guess it is a good motor. Probably I will try as well the 3.8 sometime ...
e_lm_70
Measuring Motor RPM backtrack9 XMODS Science 9 01-12-2004 05:00 PM
3.2 motor for booster car good or bad?? microsizer02 Bit Char-G / MicroSizers 3 09-12-2002 11:56 PM
