Old 11-24-2002, 10:24 PM
ejaf ejaf is offline
Red face question re: dual cat5 antenna
Dumb question...
Looking to do a dual CAT5 antenna mod to the PCB, but with two strands of wire, it won't fit through the hole on the PCB.
Should I solder the second strand a little higher up the first strand, and then solder the first onto the PCB, or am I missing something?
As an aside regarding this...would it be OK to take a single strand, double it over, and then twist it together and solder it on, or is that inviting signal cancellation?
Old 11-26-2002, 02:52 AM
Timmz69
Well I took 2cat 5 wires and twisted them and then I took another 2 and twisted them. I took both of them and twisted the ends together and then solder it on. I went from 8 feet to about 18. I can use it as a weapon now two...I did some soldering and put points on them....deadly weapons......here kitty kitty....mooooaaahhhhhhhh....Later
Timmz69
Old 11-26-2002, 08:42 AM
Wow 4???
It looks good, and you get better receiving. Question remains, though...
Did you just solder it on without putting the strands through the hole on the PCB? I can't get two twisted together, let alone 4!
Old 11-26-2002, 08:46 AM
Bryan4691's Avatar
Bryan4691 Bryan4691 is offline
Asia-Link Racing
On my Zip Zap and both of my Bits, i solder on conductor into the board and then one about .1" up from the PCB board. It seems to work great for me. I am getting about 20~30 feet inside.
Old 11-26-2002, 03:29 PM
Thanks, Bryan...
I will try that method.
E
FS: Internal Dual Cell Bit w/ telescopic antenna upgrade syncronized For Sale/Trade 1 06-09-2003 09:39 PM
Internal Dual Cell Question SuperFly Bit Char-G Mods and Projects 0 05-05-2003 02:53 PM
cat5 antenna for internal wiring 8ate8 Bit Char-G / MicroSizers 5 12-26-2002 04:59 PM
Cat5 vs Cat5E for car antenna material mechanist ZipZaps 6 10-13-2002 12:59 AM
dual battery mod question Alex Bit Char-G Mods and Projects 5 09-08-2002 06:44 PM
