Go Back   TinyRC.com > 1/64 and Smaller > Digi Q > Formula Digi Q
Old 11-24-2002, 09:33 PM
gertman's Avatar
gertman gertman is offline
Cool Gertman's F-1 thread
Hey, hey
My Formula Digi-Q finally arrived yesterday!! Before I give my thoughts on it, I want to describe some things about it that have been abscent in other threads.
First of all, I know someone is going to ask this question:
What is the difference in size between the Formula Digi Q and an Epoch?
Well, here is the answer:
-Engineering Manager
Old 11-24-2002, 09:35 PM
gertman's Avatar
A dead-on side view:
Old 11-24-2002, 09:36 PM
gertman's Avatar
Here is one with some height:
Old 11-24-2002, 09:37 PM
gertman's Avatar
From the front:
Old 11-24-2002, 09:44 PM
gertman's Avatar
As everyone who has one found out, the car steers with the REAR wheels like a regular Digi Q. BUT the difference is, the front wheels are hooked together with a tie-rod and will turn left and right. This does assest in helping the car turn tighter than if they didn't turn at all.
An important note to add here is the front tires are plastic and the rear are rubber EXACTLY like a regular Digi Q.
Getting back to the front end................the front "suspension" is a rigid swing axile. It rotates about the center of the car. The red arrows indicate the direction of possible motion. A red dot in the appoximate center about which the whole assembly is able to rotate. The red line is the approximate center of the axile.
See the picture below:
Old 11-24-2002, 09:49 PM
gertman's Avatar
The front assembly is complete with knuckles and a tie-rod. The motion described in the previous post is ALL the "suspension" or movement the car has in the front or rear. So there is NO WAY the car could bottom out!!
Here is a close-up of a knuckle and tie-rod:
Old 11-24-2002, 09:52 PM
gertman's Avatar
Here is another picture of the whole front swing arm suspension:
Old 11-24-2002, 10:02 PM
gertman's Avatar
For those of you who can't tell, still confused, or having the pictures come out dark, I have color keyed the picture:
The lower suspension arm. Remember it is ONE straight piece.
This is the upper suspension arm. It too is ONE straight piece.
Neither side of the suspension can move independently from one another.
this is the tie-rod that connects each front knuckle (hub)
This tie-rod only connects one knuckle to the other, it is not driven nor does it drive anything else!!
Old 11-24-2002, 10:16 PM
gertman's Avatar
Now, as far as how all this stuff works........................
I think it works better than the regular Digi Q BUT certianly NOT better than servo controlled front steering aka an Epoch.
As far as speed, it is about 1/3 slower than a regular Digi Q.
I have primarily been driving it on a rather slick wooden floor. I think it drifts rather well and is not as squairlly compared to a regular Digi Q because of the longer wheel-base (The F-1 is over twice as long as a regular Digi Q and 1/8" wider)
Since everyone else had already said the F-1's didn't steer with the front wheels, I wasn't dissappointed about that. What I was dissapointed about was the speed. I really was expecting for something almost as fast as the regular Digi Q's.
I think this car rates somewhere between a Digi Q an a Bit Char-G. I am glad to have one but I see how others may be very disappointed.
Old 11-24-2002, 10:24 PM
irc irc is offline
Nice review Gert
" THINK FAST "
Old 11-24-2002, 10:46 PM
gertman's Avatar
The remote that comes with the car appears to be a regular ol' Digi Q Special only black. BUT, as many have found out it ONLY works with a Digi Q Formula.
The car is attached to the back of the remote for charging BUT it is not recessed as in the regular Digi Q's. Also there is a button that when depressed raises the battery charging contacts.
Old 11-24-2002, 11:11 PM
gertman's Avatar
Now, when I just manually rotate the left rear wheel, the front wheels turn right, as they should. BUT, when I turn the right rear wheel, the front wheels only turn slightly left. I have been trying to figure out exactly why with not much luck. It seems the pins on which the tie-rods rotate were heated and flowered (mushroomed) to hold the tie-rod on. This basically means it's permanently on there
As far as how this effects handling:
The car makes MUCH sharper right turns BUT it also spins out more when turning in that direction. I think the car will need a little work with the front end to improve the handling.
GTR's Avatar
GTR GTR is offline
Bravely Runs Away Away!!
looks flimsy...
Old 11-24-2002, 11:54 PM
henry's Avatar
henry henry is offline
13B REW
is it faster then epoch?
Old 11-25-2002, 01:16 AM
gertman's Avatar
Ummm sorry to burst your bubble here Henry, BUT I did say that the F-1's are slower than regular Digi Q's. And since Epoch's are faster than Digi Q's it would be reasonable to assume that F-1's are slower still than an Epoch.
New Article: Gertman's 4-cell Mod tinyrc Epoch RC1/43 Parts and Hop-Ups 24 12-25-2005 06:17 AM
Mid-Atlantic Modders Thread PWalk Bit Char-G / MicroSizers 3 07-24-2003 03:10 PM
Kidriffic 4x4 development thread. 93civicdx Bit Char-G / MicroSizers 26 06-29-2003 09:17 AM
Kings of Chaos links thread Impreza WR reX Miscellaneous Discussion 0 03-28-2003 09:42 PM
About the '~Check This Out Please~' thread Namuna Bit Char-G / MicroSizers 0 12-20-2002 03:18 PM
