Old 11-24-2002, 08:44 PM
Vincent Vincent is offline
Steering problem
Hello to all, I'm new to this forum.
I have an older Bit Char-g chasis from the first series (blue Skyline). I've had it for almost a year now. Lately it's had a problem with steering. The steering no longer springs back to the netrual position as it used to. I tried bending the spring a bit to force the steering back to the center but this doesn't work. I've cleaned the magnet and everything is fine.
The car has no problem pulling the wheels to the right or left as they are supposed to, it just doesn't recenter anymore.
Thanks for any help.
I always tell the truth. Even when I lie.
Old 11-24-2002, 11:11 PM
*bump*
Old 11-24-2002, 11:51 PM
jaws's Avatar
jaws jaws is offline
i have learned to deal with mine i have looked and looked for the right fix people on this forum have been very helpful but i dont know what to do with mine i think this is going to be my life looooooooong thing to figure out sorry....
Old 11-25-2002, 01:11 AM
Ok, after posting I pulled the car apart and started bending the steering spring into different shapes. Like I said, the car is old and this has caused the steering spring to go kind of limp over time.
The edges extending from the spring were not completely over the trim nob. I finally bent the spring into a shape so that they would be around the nob giving the wheels the ability to spring back into the neutral position. It's not a perminant fix, though. The car still isn't like new. A new spring should fix the problem.
I used to have the AE86 collector's set (the origional with the red and panda bodies). I gave it to a friend because while cleaning it, I lost the steering spring. He finally found a replacement. He used a calculator that had a spring loaded top (the kind where you hit a button and the top flips off to reveal the crystal screen and then over the back to prop the calculator up).
They can be bought at most office supply stores for cheap.
Hope this helps anyone who has either of these problems.
Steering problem rody XMODS 1 01-29-2007 11:18 AM
Really Bad Steering Problem, unlike any steering problem before it! 'Vette Nerd ZipZaps SE 11 07-19-2006 11:05 AM
Steering problem, need help? Mike129 ZipZaps 3 10-20-2002 08:28 PM
AH-HA!!! Solved uneven steering problem! mechanist ZipZaps 8 10-17-2002 10:24 PM
