Go Back   TinyRC.com > 1/24 and Smaller > ABC DTM > ABC DTM Electronics
Old 04-26-2002, 11:00 PM
DAMZer's Avatar
DAMZer DAMZer is offline
Micro Electronics
I own an SP and use the following electronics which fit well in the low body clearance and perform flawlessly:
Orion Flashpoint ESC
Airtronics Micro 3 Channel FM RCVR
Hitec HS-55 steering servo
Airtronics M8 Radio
Had to buy the ESC and the servo, but transferred the balance from my 1/10 road car.
The Flashpoint ESC gives great proportional throttle control with soft braking and reverse for the "oops" factor. The Flashpoint is also very thin and can be servo taped to the servo, perfect for the low body clearance and limited space under the PC shells.
Old 04-27-2002, 06:46 PM
tinyrc's Avatar
tinyrc tinyrc is offline
DAMZer, is that a one or two tier setup?
Old 04-27-2002, 09:23 PM
DAMZer's Avatar
I guess you would call it a single tier.
The flashpoint is on top of the servo, capacitor to the driver's side.
The receiver is as far back against the body mount posts as possible on top of the battery case.
Old 04-28-2002, 02:49 PM
tinyrc's Avatar
How about a pic?
Old 04-28-2002, 05:14 PM
DAMZer's Avatar
You asked for it.........
Old 04-28-2002, 06:45 PM
tinyrc's Avatar
So what batteries are you using in that compartment, the ABC pack?
Old 04-28-2002, 08:44 PM
DAMZer's Avatar
You got it, bought 2 packs but have yet to thoroughly kill one
Old 04-29-2002, 03:47 PM
Hardtrukr's Avatar
Hardtrukr Hardtrukr is offline
I'm The Youngin' of R/C
Send a message via AIM to Hardtrukr
wooohhhhh coons! looks like you do have some micro electronics there. thats and $80 esc!
Hey Officer, Did You Stop At The Donut Shop On The Way Here?
Old 04-29-2002, 08:17 PM
DAMZer's Avatar
Don't know about 80, got it for about half that by supporting my LHS.
Old 05-21-2002, 12:50 PM
MicroRCEngineering MicroRCEngineering is offline
nomotorlimit@hotmail.com
an alternative would be the ES-01. It's $25.00 regularly. works up to a 180 motor, with 6 cells. That's a good set-up.
Endless possibilities with the ABC's
Old 05-21-2002, 01:54 PM
Hardtrukr's Avatar
the ES-01 is a pretty small little thing for an ESC.
Old 05-30-2002, 09:30 AM
akura2's Avatar
akura2 akura2 is offline
A Novak XXL Reciever is about 1/2 the size of that Airtronics monster... you should look into it to go along with that Orion Esc
It's about the size of the Mini servo that comes with the X4's CRP
My SP
Futaba MC230CR Esc
Novak XXL Rx
C-Can Slot car motor
6-cell pak
My X4
ABC CRP
Orion Elite Stock (180 sized motor)
ABC 7.2v 110Mah Nicad
Old 05-30-2002, 07:35 PM
DAMZer's Avatar
Yep, I run the XXL in my XXX. Can I buy a vowel?
Good example of using what was laying around in the toolbox.
Now I don't have a backup for XXL.
Old 06-09-2002, 03:10 AM
The Thunderer's Avatar
The Thunderer The Thunderer is offline
Does the capacitor come attached to the ESC or did you attach it? If you did attach it, how do you know when to do something like that?
"Jim, I'm an R/C amateur, not an electrician!" (for the benefit of any ST fans on the board!)
"Its the least I can do for the Captain of the Enterprise."
"Where there is lightning, there is The Thunderer."
Old 06-09-2002, 07:59 AM
DAMZer's Avatar
The capacitor was installed by Star Fleet Engineering in the space dock. Except for the initial definition of the warp drive parameters, I did not have to do any further tweaking to the warp drive specifications.
Translation, it came factory installed. Initial set-up was performed following the mfg's specifications. Easy, no hassles.
How To Build a Micro Speed Control From a Servo Overlander TTTT 20 05-26-2004 12:21 AM
rtr hpi micro rs4. spy esc, 2 bodies, plus extras isk8blind For Sale/Trade 0 08-31-2003 04:38 PM
FS - all BRAND NEW unopened; 1 HPI Micro RS4 RTR, 1 Kyosho Mini-Z RTR, 1 Mini-X RTR bluemax_1 For Sale/Trade 1 03-19-2003 04:49 PM
MY Custom Micro RC Story JadeFoxx Bit Char-G / MicroSizers 5 12-28-2002 09:57 PM
Canadian Micro Grand Prix lornecherry Bit Char-G / MicroSizers 9 10-03-2002 01:36 PM
