Old 11-19-2002, 11:04 PM
sillyboi sillyboi is offline
custom steering coil?
hello, i have a bit char g, and i was performing the dual cell mod, but i accidentally tore of the steering coil.... and i have read that u could buy enamel magnet wire and make your own coils, has anyone actually done this replacement mod?? and what AWG size of the wire should i get?? thanks
Old 11-22-2002, 12:15 AM
Acceptable_Risk Acceptable_Risk is offline
You might be able to, but you're gonna need to be very precise. If you just broke one of the wires you can solder it back together. If it's the actual coil that is damaged, I'd almost say you're out of luck.
Single/Multi coil steering columns cm961 Bit Char-G / MicroSizers 4 07-28-2003 10:59 PM
resoldering steering coil wires to pcb jedclampit Bit Char-G Mods and Projects 2 03-22-2003 07:49 PM
Best Diy Steering Coil Guide scottyboyfun Bit Char-G Mods and Projects 2 02-13-2003 07:02 PM
Steering Magnet Coil Wires kmvargo Bit Char-G Mods and Projects 1 02-13-2003 04:22 AM
