Old 11-19-2002, 06:19 PM
Sgt Fox's Avatar
Sgt Fox Sgt Fox is offline
TinyRC Fox
Question Switch between 45 and 90 second charge?
Would it be possible to install a switch in the positive side of the capacitor so that you could switch between the 45 sec nd 90 sec? anyone with an electrical degree know?
Old 11-20-2002, 09:46 AM
Sgt Fox's Avatar
TinyRC Fox
no i really only want 45 or 90 second charged time
Old 11-21-2002, 09:42 AM
Acceptable_Risk Acceptable_Risk is offline
I did the a voltage switch mod a few weeks ago, only I used a SPDT switch. If you're not interested in having 3 volt charging, you should be able to just switch the postive lead of the capacitor in a similar fashion. Am I wrong? At very least, you can use a DPDT for it, and switch both leads.
Old 11-21-2002, 09:57 AM
Sgt Fox's Avatar
TinyRC Fox
Yeah i talked to an electrical engineer and he says it would work so here are the revised schematics
