Old 07-23-2002, 03:20 AM
Tech_Lord Tech_Lord is offline
o_0
Talking Led Question
Hello
i have a question for the led installation. can you do what it says on the TIny RC Led installation mod and put back leds on as well without getting a larger battery or anything
Old 07-23-2002, 09:36 AM
Wedginator Wedginator is offline
I luv LEDs
Yes and no.... Depends on which combination you use. For example if u use 2 yellows and 2 greens, then it will work. But if you use 2 yellows and 2 reds, then it won't work. THe reds will suck up most of the amps and leave the others dim. It's best to choose LEDs about the same brightness.... This comes from experience....
Old 07-24-2002, 02:37 AM
o_0
Talking
thx for the info cause i was thinking of using 4 reds! and is it a good idea to use leds?
Old 07-24-2002, 09:07 AM
I luv LEDs
I haven't tried it with 4 reds b4. But all I know is whenever you use the same types, then the brightness will be split equally among the 4....
Old 07-25-2002, 04:39 AM
o_0
thx heaps you have been a real good help! also are there any really good sites with good mods on them cause im looking but i cant find!
Old 07-25-2002, 10:31 AM
I luv LEDs
There's this site: http://questformadness.com/
LED light kit question Chris XMODS Parts and Hop-Ups 8 10-28-2003 09:52 PM
LED switch Turboas ZipZaps 10 05-18-2003 01:50 PM
Unusual LED behavior InGaN Miscellaneous Discussion 0 01-30-2003 08:31 PM
Led question Riven Bit Char-G / MicroSizers 1 01-02-2003 09:08 AM
Bad LED bulb? The Dude Bit Char-G Mods and Projects 7 11-15-2002 02:47 PM
